Shuddering in 1st caused by engine hesitation?
Had a new clutch & hydraulics installed, now the car shudders going into first gear. Only happens when i keep it between 800-1400RPM's. The mechanic said that the car is hesitating/missing and thats why the car shudders? I notice a hesitation in 1-3, kind of like the car is surging, so i'm going to clean the TB and replace the fuel filter. But would that cause the car to shudder in 1st? Any help is appreciated
The clutch should be worn in by now, i'm about to hit 7000 miles on it??
Originally posted by tmkforever
I don't know what kind of clutch you installed, but it probably has to be worn in before the 1st gear chatter will go away...like 500 miles.
The shop that did the work, said they did everything. I'm not sure whether i believe them or not though.
Originally posted by KMax2988
Did you get your flywheel resurfaced before you installed the clutch?
Check your knock sensor...Check your ECU...it is more than likely your knock sensor that is bad and throwing off your timing. This would cause the hesitation..I had the same problem along with many other 4th gens....Check that along with clean throttle body and replacinf fuel filter
Thanks for all the suggestions. I'm going to check my ECU, from what i've been reading about a bad knock sensor it sounds like that could be part of my problem. There is hesitation, noticeable through third gear. The enging sort of surges, then gets choked, a little jerky once i get over 2500-3k RPMS. Also, i just dont have the power i should, couldnt pull an inch on my buddy's bone-stock g20. Thats just not right. Once again, thanks for the help. I'll let you know how it goes.
Talked to a tech at work and he is almost certain that your flywheel wasn't cut properly. He told me the only reason he believes a manual would chatter when taking off is due to the flywheel surface not being perfectly flat. Hope this helps.
97_GXE
09-15-2015 06:47 AM
trungg86
09-04-2015 04:58 AM
