How to test fuel injector
Old Nov 8, 2004 | 04:47 PM
Brooklyn Legend's Avatar
I tried to get the ohms measuremts from a fuel injection rail today but could not do it right I guess. turned the **** on the unit to ohms put it to 2000 like the book says, conect leads to fuel injector and I get crazy numbers that go up and down, then I get 1 on the screen again. I am using a digital multimeter. does this mean injector is bad, this is an injector that is not attached to a car that I tested. When I tried to test the injectors on the car I got the same reading. So either every thung I tested is shot or I dont know what Im doing. Can someone explain to me breifly if Im doing it right.
this is the ohm meter I am using is it able to do the job Im lokking to do?
http://www.sears.com/sr/javasr/produ...id=03482141000
Old Nov 8, 2004 | 05:01 PM
internetautomar's Avatar
mod or sell?
it should be set to 200 (approx 7 o'clock) you just measure by touching one probe to each prong onthe connector.
Old Nov 8, 2004 | 05:07 PM
aminus21's Avatar
what he said.
Old Nov 8, 2004 | 05:51 PM
I did that and all I got was the single digit of one. Does that mean the injector is dead.
I know the multimeter is working because I tested a AA battery.
Old Nov 8, 2004 | 06:13 PM
aminus21's Avatar
you have to kinda play around with it, and some times apply a LITTLE pressure. what I did was stuck the tip of the multimeter to the root of the injector connector, then i pulled it back a little creating a small amount of pressure. ...
try to undertsand that
Old Nov 8, 2004 | 07:40 PM
DARHAW-MAX's Avatar
I am sure that you did, but are you sure that you had the leads installed in the right receptacles? Looking at meter, you should have the black--common--lead in the center and the read lead in the right. The one that reads "VohmmA"
Old Nov 10, 2004 | 03:16 PM
-shock211-'s Avatar
do what aminus21 said.
i had to change the injectors on a buddies vg last weekend. my multimeter was going screwy to because of corrosion on the injector connectors. if you scratch the tips of the connectors a little bit you'll be able to get a steadier reading.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
