Fidanza and ACT Torque specs
Originally Posted by 505max94se
They are the same as the stock specs so just look in your service manual. If you don't have one I could look them up in mine.
Then what are the specs? I torqued all of mine to stock specs. Just be carefull when bolting down the PP to the alumin flywheel. The threads are soft aluminum and easy to strip. The clutch specs is pretty low. Too low IMHO. The flywheel is pretty high.
Originally Posted by MrGone
Are you sure about that?
They don't come with bolts or washers anymore.
I just remember Fidanza providing a sheet with all the torque specs on it. Plus the flywheel comes with the different style bolts with lock washers.
your service manual has the answers. put a drop of blue loctite on the threads holding the PP to the flywheel too. it's a pretty low torque and I feel better with some loctite on the bolts holding it in..
then again, mine's been in there for two years without a problem.
jmlee44
10-02-2022 02:13 PM
The Wizard
24
10-01-2015 08:47 PM
