hey, you lighting experts
Old Nov 11, 2004 | 11:01 PM
Cliff Clavin's Avatar
Way out West
I normally don't give a crap about lighting, but I decided I want something different than I currently have in my foglights.
Do you guys think the stock wiring harness for the fog lights can handle 85 watt bulbs?
I don't really want to bother with upgrading the wiring harness, but the cost difference between 55w and 85w is negligible, so I thought I might just order the stronger bulbs.
Any thoughts or ideas?
thanks,
chris
Old Nov 11, 2004 | 11:18 PM
Harvs94max's Avatar
ive got 100watt bulbs in my se fogs and havent had a problem with it buring out the wiring if it does i can just upgrade
Old Nov 12, 2004 | 08:02 AM
DMad8724's Avatar
I don't really have much to say because I don't have foglights at all, and I'm sure the OEM harness is different than aftermarket ones, why not try finding an H3 upgraded wiring harness on ebay and go from there
Old Nov 12, 2004 | 06:06 PM
-shock211-'s Avatar
run em' until the harnesses melt. it probably won't happen very quickly because the fog lights aren't running constantly. i give the harnesses 3 years before melting.
Old Nov 12, 2004 | 06:33 PM
Way out West
hahaha, that would probably be about 9 years for me, then. In the last two years I haven't even driven my car 3,000 miles. Over 90 percent of that has been in the daytime with no lights on.
thanks
Old Nov 12, 2004 | 08:51 PM
MrGone's Avatar
someone needs to do the foglight rewire while he's at it too
Old Nov 12, 2004 | 09:01 PM
Harvs94max's Avatar
i have the foglight rewire and i keep them on when ever i drive and i have had the 100 watt bulbs for about 4 months now and havent had a problem
Old Nov 12, 2004 | 09:14 PM
Way out West
I am much too lazy for that. It would at least double the time I would be out in the cold garage.
Old Nov 12, 2004 | 09:17 PM
MrGone's Avatar
1. aim.exe
2. sunday, 11/14/04 = chris mod day
3. i dunno
Old Nov 13, 2004 | 09:20 AM
DMad8724's Avatar
I might do a foglight harness upgrade while I'm at it
Old Nov 13, 2004 | 12:24 PM
MrGone's Avatar
[img]http://image18.webshots.com/18/5/75/46/215857546Rndakg_ph.jpg[img]
are you making whole new harnesses for your corner lights/fogs/headlights?
I guess I could see the corner lamp thing if your running a higher wattage bulb, but be careful, as when the cornering lamp is on it is really bright for oncoming drivers. Also if you wire it right, you can have the corner lamp rewire and the fog light rewire, and still be able to pull your corner lamp and take it to a bench just by disconnecting the little connector.
Old Nov 13, 2004 | 02:10 PM
DMad8724's Avatar
I'm not making a whole new harness, I took the aftermarket harness from some clear corners I got as a present and rewired them the way I want them, using LED bulbs and xenon bulbs in the corners, also it's rewired for the LED turn signals, and theres a relay for the lo-beam of the projectors, hopefully everyone will be able to see it soon. I just ordered my tinted corners from mike today and the LEDs for the turn signals, still have to get the amber paint and sand/buff my bumper signals
vingodine
45
May 21, 2016 12:46 PM
4doorGTR
Sep 11, 2015 04:09 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
