VTC sprocket trouble. HELP!!!
I just bought a 92 max and was told the VTC sprockets were in need of replacement. I did some searching and found that they could be bypassed. Anyway, I did the bypass and the chattering is still going on. I grounded the yellow/green wire and took the harness off it and it still happened so I removed the other harness and yet again it still happened. What am I doing wrong?. Could it be anything other than the VTC sprocket?. If yes, what could it be and if no then what is up with it?. Any help would be appreciated. Thanks
Originally Posted by Jeff92se
VTCs could be just that bad. You cannot "bypass" them. Only configure them on or off. But if the spring is too weak, it will clatter like a diesel all the time.
Originally Posted by Maxima-4DSC
take them out = free
rebuild kit = 60 bucks give or take
reinstall = free
nissan to rebuild them for you = 125 +/-
non-diesel maxima = priceless
reinstall = free
new engine after bad luck with rebuilding VTCs= $1500
I'm probably gonna be doing mine soon so I'm hoping to learn from your bad luck.
when mine start to clatter I just add oil
GTFO ---------->
Originally Posted by «§»Craig B«§»
I think you left out one step
at the very least, unbolt the tranny mounts and give the engine that gangsta lean
dont worry between me and you (and hopefully doing that other set a day or so earlier
) I think we will have it covered pretty well.
why? it lets me know when it's too low.
isn't that what the oil light on the dash is for? :bonk :
Originally Posted by awsm66
OUCH!!!
I want in on that gangbang
My JDM VTCs clack just a little bit on startup. I have the toyo filter, but I guess it's inevitable.
Originally Posted by Red92MaxSE
Shawn might know a thing or two about this
back to the original post here...
You said you grounded the wire but then "took the harness off it" right?
You are not supposed to take any harness off at all to do this.
Ground the wire and leave the harness on. You have to engage the solinoid and to do that the harness has to be connected.
I may have totally misunderstood what you wrote but if I didnt go back and reconect the harness and be sure you have a good ground.
Originally Posted by MrGone
think maybe now you could check the dipstick now? I just wanna know how much you have in there.
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
