tire wear issues
Old Nov 12, 2004 | 09:22 PM
90maroon15.1's Avatar
tire wear issues
about a month ago i put my winter stock rims on with new tires.. they have 360 treadwear and in the front they're already going bald on the inside. i have tokico struts with B+G 1.5" drop springs... the back tires wear evenly and still look brand new. im debating on getting eibach 1.2" drop spring and see if that helps or else im just gunna get all of the regular springs/struts so it sits at the stock hight, what do i do?
Old Nov 13, 2004 | 04:53 AM
Greeny's Avatar
¯\(°_o)/¯
You might need an alignment, or it could be your ball joints need to be replaced.
Old Nov 13, 2004 | 07:38 AM
Matt93SE's Avatar
STFU n00b!
Get an alignment first.
have the shop check control arm bushings, tie rod ends, ball joints, and strut mounts. all common places of wear/failure on these cars.
Old Nov 13, 2004 | 09:30 PM
thanks im taking it to the the shop tomorrow.. my neighbor is the manager of the local Firestone so he'll hook me up with some nice potenzas and see whats up with the suspension
Old Nov 13, 2004 | 09:31 PM
if all of the control arm bushings, tie rod ends, ball joints, and strut mounts are fine then would i need a camber kit or something like that
Old Nov 14, 2004 | 05:38 AM
internetautomar's Avatar
mod or sell?
not with those drops you shouldn't need one
Old Nov 14, 2004 | 08:50 AM
when would u need one... past 2"?
Old Nov 14, 2004 | 11:09 AM
mod or sell?
not 100% sure, but the eibach 1.2 is generally considered OK
Old Nov 14, 2004 | 09:15 PM
maxmvp's Avatar
Eibach says that you need to use their camber kit with the lower kit. I am having the same proble with the camber kit. I think I need to change the bushings on my lower control arms.
Old Nov 16, 2004 | 08:26 AM
i cant even have it aligned because the equipment has no clearance to hook onto the wheel.. so i think im just gunna go back to stock suspension... 3 sets of front tires in 6 months is too much
Old Nov 16, 2004 | 08:33 AM
Matt93SE's Avatar
STFU n00b!
Whaaa? no clearance to hook onto the wheel?
take that thing somewhere else. the guy is a retard.
If not, then put some other tires on it and drive it back onto the rack. it wont change your alignment...
Old Nov 16, 2004 | 12:52 PM
Jeff92se's Avatar
I'm needing a caw
Firestone checked/aligned my car with Eibachs. It's not brain surgery.
Note: my old 3-gen with Eibachs could have used some camber correction
my newer with the same suspension didn't need it
Old Nov 16, 2004 | 02:06 PM
Matt93SE's Avatar
STFU n00b!
old/new... what's the diff? they're both 92 VE 5 spds.
Old Nov 16, 2004 | 02:15 PM
Jeff92se's Avatar
I'm needing a caw
Different sets of strut mounts and the suspensions might have diff amounts of wear on them. Point being, just because you have Eibachs, doesn't automatically mean you don't/won't need some camber correction.
Old Nov 16, 2004 | 02:21 PM
Matt93SE's Avatar
STFU n00b!
I know.. I was just giving you crap.
what's the difference between a "new" 92 maxima and an "old" 92 Maxima? about two door dings.
Old Nov 16, 2004 | 02:23 PM
Jeff92se's Avatar
I'm needing a caw
ACtually my old one was alot cleaner in the body/paint. Everything else is about the same as I swapped everything over except the tranny. Leather/engine/now has Konis/Eibachs etc...
MR2 T'd
Jul 9, 2021 05:06 AM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
