Crazy Headlights
Old Nov 15, 2004 | 05:59 PM
way2fast's Avatar
Crazy Headlights
Ok so now im peaved. I have been messing with my headlights for the last couple of weeks and i can't get them fixed. My driver side headlight doesn't work at all. Nothing, no daytime running lights, no lowbeams, no highbeams. The only thing remotely close to a light is the blue high beam light on the dash that comes on, when the car is on. so far ive changed the light harness, and changed the switch twice once with one from the wreckers, and the original that i had pulled appart and cleaned all of the "fingers" inside the switch. If anyone has any ideas please help me, i can't get my car insured until it passes the safety inspection. thanks
ps. i have replace the fuses under the hood by the battery, and but several new bulbs in.
this is so frustrating!!!!!!!!
Old Nov 15, 2004 | 07:52 PM
way2fast's Avatar
Ive been told to check the heatlight relay, can somone tell me where it is and how to check it.
Old Nov 15, 2004 | 08:02 PM
DMad8724's Avatar
Assuming you're using stock headlights, here's my suggestions to you...go buy a new harness (9004) and a new bulb...hook the harness up the battery to make sure the socket and bulb work...if this works...hook it up to your existing stock wiring if it doesnt work, then either your headlight stalk, or wiring is bad, or something else...I'm gonna look in my books to see if I can find the "headlight" relay...I'll get back to you
Old Nov 15, 2004 | 08:04 PM
shvelle's Avatar
I could be wrong, but I think it's under the hood in the same spot as the headlight fuses? The top of that relay/fuse box should be marked, clearly telling you what is what. Do you not have a Haynes manual? If not - get one - it'll help a lot. (mines at the shop, otherwise I'd check for you)
Old Nov 15, 2004 | 09:01 PM
way2fast's Avatar
Thanks for the replys. Unfortunately i don't have a hayes, but it's quickly becoming apparent that im in definate need of one. ill check the black box with the headlight fuses in it tomorrow the headlight relay.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Garrettz459
Sep 28, 2015 02:50 PM
Noela
Sep 26, 2015 08:22 AM
