Leaking Brake Fluid in Cold Weather
Old Nov 17, 2004 | 12:04 PM
crsmax's Avatar
It seems that I am losing brake fluid from the master cylinder (or at least the resovoir is low) every morning that the weather is cold. Additionally there is a puddle of fluid in that same general location as the master cylinder. I do not see the fluid actually leaking out, but the black housing for the steering column looks a little damp. Any ideas what is causing this?
Old Nov 17, 2004 | 01:11 PM
internetautomar's Avatar
mod or sell?
a seal that is contracting from the cold.
Old Nov 17, 2004 | 01:13 PM
Knight4's Avatar
Possibly a hose or gasket is dry and brittle? The cold weather might be making them contract, allowing the fluid to leak out through the cracks???
Old Nov 17, 2004 | 01:14 PM
Jeff92se's Avatar
I'm needing a caw
Seal inside the MC is failing. Replace asap.
Old Nov 18, 2004 | 06:24 AM
crsmax's Avatar
Thanks for the info... this morning, I could actually see the moisture on the black cover of the steering column... (the cover that attaches to the fire wall...) is this the steering column, or part of the brake booster for the Master Cylinder? Also, is there a gasket in this peice, or can the whole assembly be replaced?
Old Nov 18, 2004 | 06:53 AM
mod or sell?
if you're leaking that bad, then you may also have to replace the booster and not just the master cylinder.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
The Wizard
24
Oct 1, 2015 08:47 PM
bbsitum
Sep 11, 2015 04:55 PM
ag90fox
Sep 9, 2015 12:22 PM
