VE30DE doesn't start (HELP!!!)
THE MAX JUST HIT 200,xxx miles.....
anyways i filled up the gas tank early that day then later on that evening the max wont start at all.....all it does is sputter and huff its last breath away when i try to start it.......could it be the fuel pump, injectors, etc.......
well... when you turn the car to "on" do you hear a sound comming from the rear for like 2-3 seconds?... Sounds like a hissing sound. If you hear that then its not the fuel pump.
Does the car crank? When was the last time you changed your timing belt?
u know what, it might be the fuel pump......when i turn it on it used to make that hissing sound in the back but now there is no more hissing sound.......but the car cranks thou......anybody knows where i can get a walbro or a oem fuel pump for cheap around here???
trungg86
Sep 4, 2015 04:58 AM
