Car is finally done....
Old Nov 20, 2004 | 05:55 AM
MethMax's Avatar
Yeah I finally finished installing my new engine but it doewsnt start, gonna try and mess with it maybe after I get off of work today. I pulled one of my plugs and it was soaked in gas. So well see what happens.
Old Nov 20, 2004 | 07:06 PM
MethMax's Avatar
Can anyone offer any suggestions?
Old Nov 20, 2004 | 07:36 PM
sara92max's Avatar
not gettin fire
Old Nov 21, 2004 | 05:06 AM
GRNMAXDMON's Avatar
it doesn't crank at all or it cranks???
check all ur plugs and wirings maybe u have missed something there. wish i can give u more specific places where/what to look at but i haven't done an engine swap "yet" on my car. hopefully one of the moderators here can help u out or anyone else that has some experience on this as well.
good luck,
Rick
Old Nov 21, 2004 | 09:50 AM
DanNY's Avatar
Ad·min·is·tra·tor
is your distributor in the right position?
Old Nov 21, 2004 | 07:13 PM
3rdmaxse0's Avatar
I just finished a vg swap in my friends 91' and like danny said check ur timing set ur crank pully at TDC wich is the second indent matched with arrow and crank it and play with the distributor turning it slowly if not getting better and hearing fireing through intake take off cap and put a mark on the exzact oppisite side of the point and take distributor out and line up point with distrubutor going like 1/4" clockwise because of angle of gear will turn it alittle. now start it againg and again move distrubutor by turning slowly until engine runs smoother and get a timing light and time it. hope this helps. check if all wire harnesses are plugged in and make sure coil is good
Old Nov 21, 2004 | 07:33 PM
MethMax's Avatar
yeah I was just talking with my friends dad and he was saying that my disributer could be off 180 degrees. I might have put it in when I thought it was TDC, cause im pretty sure that I did the belt right so tommorrow im goiung to try the distributer.
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
JMag90
Aug 25, 2015 09:17 AM
maxinout93
Aug 16, 2015 07:25 PM
Max8
Aug 15, 2015 07:06 AM
