VG Tranny Question
Old Nov 20, 2004 | 10:31 AM
mike92's Avatar
VG Tranny Question
I was driving on the highway at 100 mph (after a 200 mile trip) suddenly the tranny engaged into 3rd gear and back to fourth gear with no reason (very fast). It happened 3 times in a two minutes period. Afterwards everything was normal again. The fluid level is OK and in good condition, since I change whatever it drains from the plug every 3000 miles. The tranny does not slip at any gear hot or cold and it does not have any other symptom.
Any hint??
Thanks.
Old Nov 20, 2004 | 11:10 AM
Harvs94max's Avatar
maybe it was your car telling you not to drive like an idiot
Old Nov 20, 2004 | 11:19 AM
mike92's Avatar
An "I don't have any idea" would suffice.
Old Nov 20, 2004 | 11:36 AM
Matt93SE's Avatar
STFU n00b!
Gremlins man.. they've invaded your tranny.
Do you have the dropping resistor plugged in and functioning?
If so, then just keep an eye on the tranny and watch for stuff like that to happen again.
If it's not plugged in, then plug it in.
FYI, that's a sign of high line pressure in the tranny. usually that means a slow, expensive death for it. if it does it again, it's definitely a problem and most likely you're going to need a tranny shop to check it out for you.
Old Nov 20, 2004 | 11:46 AM
mike92's Avatar
Where is the dropping resistor located? what it looks like?
Old Nov 20, 2004 | 07:05 PM
subs1000w's Avatar
i think its under the air box
its small it has one bolt and one wire
Old Nov 20, 2004 | 07:57 PM
AscendantMax's Avatar
you don't need to change your tranny fluid every 3k miles...
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
Socalstillen
Sep 20, 2015 11:46 PM
pktaske
Sep 4, 2015 08:40 AM
