Fuel filter replacement
Old Nov 21, 2004 | 09:48 AM
Hemphire's Avatar
Quick question guys. It is now time for me to change my fuel filter. I have read somewhere that a filter ment for the 300 would be the best choice as it is larger. What are your guys thoughts on this? Should I go with the smaller filter meant for a 94 GXE or the 300's?
Old Nov 21, 2004 | 09:54 AM
DanNY's Avatar
Ad·min·is·tra·tor
your choice...the OEM filter is fine for the car.
the 300ZX just give you more time between changes.
Old Nov 21, 2004 | 09:58 AM
Hemphire's Avatar
Thanks DanNY I guess I'll go with the OEM, Now it's time to go to Farts Source.
Old Nov 21, 2004 | 04:31 PM
Aaron92SE's Avatar
NWP Engineering.com
I personally get my fuel filter from the dealership b/c it seems to be a much nicer part than normal parts store. But remember to undo your fuel tank cap to relieve the pressure. Then remove the fuel pump fuse and try to crank your car about 3 times. That will relieve the fuel pressure. Get some rags and change the filter. It shouldn't take you more than 15-25 minutes if you are a slow worker.
Do it on a cool motor and don't smoke! Have fun!
Old Nov 22, 2004 | 01:44 PM
Hemphire's Avatar
Negative on the no smoking, I like to live dangerously. And I'm doing it during my lunch break so if it blows I get worker comp jkn
Old Nov 23, 2004 | 07:07 AM
ntjoe's Avatar
In that case, if the screws to the filter are tight, just heat them with a torch to help them loosen easier......JK of course!!!!!!!!
00MAXI
Sep 2, 2015 10:23 AM
305head
Aug 26, 2015 09:03 PM
homewrecker
Aug 24, 2015 08:56 PM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
