What front axles do I need???
Old Nov 22, 2004 | 07:52 AM
Hornswoggler's Avatar
From what I gather, my front axle half-shafts are leaking heavy grease, and need to be replaced.
I went to autozone looking for the part, and they asked me if I have ABS brakes or not.
Car is a 93 GXE. Do these come with ABS? My first thought is that it does/would/should, but I have locked up my brakes on quite a few occasions, with no ABS pulsing at all.
Anybody know if the front axle's are really that much different between ABS and non-ABS Maxima's?
Any help is appreciated.
Thanks!
Old Nov 22, 2004 | 08:04 AM
nelledge's Avatar
"I'm just sayin'..."
You have to get the correct ones. They will ask ABS, tranny, how many cams, and whether it has a highspeed diff. You can figure out if it has ABS by 1 looking under the hood 2 turn your key to the on position and look for the yellow ABS light on the cluster. If you can't find them at Autozone, try Oreilly Auto, NAPA, ICP, or an axle shops. Mine were special order ten days out, so I got a local axle shop to rebuild them for 75 an axle installed... with a lifetime warranty. They are perfect now
Old Nov 22, 2004 | 08:06 AM
dantegl's Avatar
yeah your car should have abs i believe its standard for that model.
Old Nov 22, 2004 | 08:10 AM
That's what I would have thought, but if ABS was on all 3rd gen maxima's, why would autozone even ask me?
Thanks nelle, I will check for ABS.
Old Nov 22, 2004 | 08:16 AM
dantegl's Avatar
autozones computers are odd, i got both of my front axles from there and they asked me the same question so i asked them to compare the part numbers to see if the axles were different and they werent, same axle.
Old Nov 22, 2004 | 08:22 AM
Mizeree_X's Avatar
Getting back to his roots
Wrong.....! If your GXE has rear discs, then it has ABS. Best way to check would be to pop the hood and check your engine bay:
See the unit on the left side with all the metal lines going in and out of it? That's the ABS unit. Its next to the windshield washer fluid fill neck. If you don't have ABS, your coolant overflow reservoir would be located on the left side in place of it, instead of next to the battery. Hope that helps.
internetautomar's Avatar
mod or sell?
Because AZ is staffed by complete morons!
NEVER ASSUME ANYTHING when it comes to getting parts for your car.
Old Nov 22, 2004 | 08:26 AM
Greeny's Avatar
¯\(°_o)/¯
Best thing i have found to do is take the axles off first[or any part], take it down there and match them up visually.
Old Nov 22, 2004 | 08:38 AM
nelledge's Avatar
It's not only AZ. It's rampant.
Old Nov 22, 2004 | 08:39 AM
I do have drum brakes in rear, and I do have a coolant overflow tank there, so I probably don't have ABS. (which also explains the tire lock-ups, haha)
Thanks again for the help! Mizeree_X gets a cookie!
Old Nov 22, 2004 | 08:45 AM
mod or sell?
most chain stores are staffed by people getting low pay and lacking real useful knowledge.
stick to the mom and pop store and you're more likely to end up with the right part.
Old Nov 22, 2004 | 10:19 AM
rrrfoma's Avatar
I need to replace outer CV joints too. But the question I'm asking myself - would it be easier to replace "complete" axle instead of just a CV joint? How long does it take (do it yourself, of course) for just outer CV joint and for "compete" axle?
Old Nov 22, 2004 | 11:03 AM
mod or sell?
easier : No
cost : about the same
Old Nov 23, 2004 | 10:31 AM
rrrfoma's Avatar
easier : No
Yeap, in any case I'll have to remove both axles ... "right side" first and then "left side" (outer CV on left side is bad) ...
How much would you charge for both axles (it's for GXE with ABS)?
No shipping is required - I can pick 'em up in Chicago.
And ... in this case I'll need somebody in Chicago area to install 'em (I'm not paying "customs" again). Any good shop around?
Old Nov 23, 2004 | 11:02 AM
mod or sell?
$55ea exchange sound fair?
I know lots of shops on the northside that can do it.
Old Nov 23, 2004 | 06:54 PM
rrrfoma's Avatar
Sounds more then fair. Thanks! I should be in Chicago around Christmas (including a week after 25th).
BTW, we are talking complete axles (not outer CV joints) with boots, rights?
the same as here:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7916441404
Old Nov 23, 2004 | 07:15 PM
mod or sell?
yeah they are complete, just not new. They are remanufactured.
Old Nov 23, 2004 | 07:23 PM
JMAGIC89's Avatar
smittys lmao
Old Nov 23, 2004 | 07:58 PM
kringle03's Avatar
holy crap dude... your sellng those for $55?... dang i paid like freakin $70somthin apeice for my remanufactured ones (did the labor myself of course)... screw local shops... i'm going to start ordering most of my stuff from you...
Old Nov 24, 2004 | 06:16 AM
mod or sell?
10q, axles the big problem is shipping them and then the core back.
that's why they aren't up on my site
PH98I30
29
Feb 10, 2025 12:03 PM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
