JWT ECU and gas problems
Old Nov 22, 2004 | 08:58 AM
KRMaxima21's Avatar
I drove out to Rhode Island with some friends on Friday night (got bored in Queens lol) and before I left my brother put gas in my car and he decided to put 89 octane in it instead of 93 like I told him because I have an JWT ECU upgrade. Anyway on the way there I hear this knocking sound coming from the engine and this it starts this slow hesitation like an engine was acting up or something. I wait till the tank gets a quarter full and I put about 15 dollars of 93 octane in it. It goes away for a while and then comes back. It drove fine on the way back until I got back to The Bronx area and then it started again a lil bit so I drove it around till it hit E last night and then put in 15 dollars 93 octane. It ran fine this morning and then it started the knocking thing again. Anybody knows if I really screwed up something or is it just because there probably is 89 octane in the system and I have to fully burn it out? I was thinking the ECU probably would have to adjust the A/F ratio again from the o2 sensor being that it had 89 octane in it for a while and have NEVER ran 89 with that JWT ECU. I'm hoping I don't need a new o2 sensor or a new ECU
Old Nov 22, 2004 | 10:34 AM
Matt93SE's Avatar
STFU n00b!
Nah.. check your timing and dial it back a couple degrees if it's past 15.
do you guys still use that oxygenated gas up there? If so, that may be causing some of the probelms.
Old Nov 22, 2004 | 11:36 AM
KRMaxima21's Avatar
The JWT ECU brings up the timing about 4-5 degrees and I never messed with the timing since I've gotten the car (jan. 02). The only way I can set the timing back is if I unplug it and just run my original ECU for a few hours until I burn out all of the lower grade gas. As for the gas Matt, I honestly don't know. I have to find out. All I know is that we run 10 % ethanol in our gas up here.
Old Nov 22, 2004 | 12:34 PM
Mizeree_X's Avatar
Getting back to his roots
Yeah, oxygenated gas is around......depends on the brand and/or specific station. I don't think the VE likes it. MTBE is the most common oxygenator I've seen. Mmmmmm....carcinogenic watershed ruiner.
Mar 12, 2020 12:06 AM
QueensMAX
Sep 15, 2015 04:14 AM
slowlifer
Sep 8, 2015 05:53 AM
mix master
Sep 4, 2015 05:50 PM
