!help! My Maxima Doesn't Idle Up When I Use A/c, Headlights, Accessorsries,ect.
Old Nov 23, 2004 | 11:41 PM
puna2k's Avatar
!HELP! MY MAXIMA DOESN'T IDLE UP WHEN I USE A/C, HEADLIGHTS, ACCESSORSRIES, ECT.
1990 SE A/T
IT'S DONE THIS FOR A WHILE NOW, AND IT'S GETTING OLD.
AND THE HAYES REPAIR MANUAL SUCKS A BIG ONE
Old Nov 24, 2004 | 04:47 AM
NYmax91's Avatar
sounds like a computer issue. get a code reader and see what it says or even call a nissan dealer and ask. people need not be afraid to ask service guys questions, they might tell you over the phone!
Old Nov 24, 2004 | 10:09 AM
puna2k's Avatar
I READ ABOUT A fAST IDLE CONTROL VALVE IN THE HAYES MANUAL, BUT IT DOESNT SHOW WHERE IT IS ON THE VG30. IT HAS PICS OF THE 88 MOTOR., COULD THE THROTTLE POSITION SENSOR BE PART OF THE PROBLEM?
Old Nov 24, 2004 | 10:53 AM
505max94se's Avatar
Maybe the alternator is going out??
Old Nov 24, 2004 | 11:13 AM
Scope's Avatar
Im izz sexay
I second that.
Old Nov 25, 2004 | 01:12 AM
puna2k's Avatar
Alternator Is 100%, No Dive In Voltage When I Use A/c, Headlights, Accessorsries, Ect. I'm Gonna Ohm Test Most Of My Sensors And Control Valves( Idle Air Control Valve,tps,maf. On Thanksgiving.
Old Nov 25, 2004 | 09:49 AM
puna2k's Avatar
Maf Is Good, And The Tps Is Toast - Has No Ohm Resistance At All.
I Cant Find The Idle Air Control Valve On My Vg
Old Nov 25, 2004 | 11:14 AM
internetautomar's Avatar
mod or sell?
TPS : I sell those
IAC is by the throttle body (piece where your accelerator cable connects to. right by the TPS
Old Nov 25, 2004 | 11:39 AM
Yourself
you can test your tps in "switches on\off mode"
Old Nov 25, 2004 | 11:55 AM
puna2k's Avatar
IS IT IN THE THROTTLE BODY, OR UNDER IT? AND THIS IS THE VG WITH THE THROTTLE BODY FACING THE FRONT OF THE CAR.
I TESTED THE TPS WITH A FLUKE 18 AUTOMOTIVE METER. NO OHMS AT ALL, DEAD.
internetautomar HOW MUCH $?
Old Nov 25, 2004 | 12:27 PM
mod or sell?
YGPM
IAC motor is the right (drivers side) of the TB and its on the intake runner.
Old Nov 25, 2004 | 07:39 PM
4dscPat's Avatar
Oh My God My Caps Button Is Stuck Plz Help!!!!!!!!!!!!
Old Nov 25, 2004 | 08:52 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I had the same thing happen. Just idled hard. I do miss it.
Old Nov 26, 2004 | 09:20 AM
avmaldo's Avatar
could it be a belt problem? In the winter they could be getting cold and stuck.
Old Nov 27, 2004 | 04:35 PM
puna2k's Avatar
The IAC is toast, resistance from connectors 3 to 4 is gone. time to spend some $$. and I adjusted my TPS and my car is faster on the take off, with no stumble
maxinout93
Oct 27, 2015 01:29 PM
wingsfan24
Aug 15, 2015 07:35 PM
Nintensity
Aug 13, 2015 05:41 PM
acw
Aug 13, 2015 12:50 AM
MikesChevelle
Aug 7, 2015 05:57 PM
