How to remove front bumper and lights?
Old Nov 24, 2004 | 07:36 AM
Brooklyn Legend's Avatar
How can I remove the front bumper and headlights thanks
Old Nov 24, 2004 | 07:44 AM
DanNY's Avatar
Ad·min·is·tra·tor
pull corner lense out.
2 10mm bolts on the side (attached to inner fender)
2 10mm buts behind the headlight (it's close to the long adjusting bolt)
undo the plug and headlight is out.
squeeze the clips in the grill to pop the grill off.
take the 10mm bolts from the top of the bumper on the sides..(feel free to curse when you break them). it might help if you remove the inner fender liner.
pull the metal strip out.
remove the nuts that's between the bumper and the fender...also 10mm. repeat for both sides.
under the car remove the bolts that's above that mini grill (strip of plastic)...again feel free to curse when they break off. take out the plastic grommets/clips...(push in the center and they pop out)
disconnect any inner fender liners attached to the cover. at this point it should be nice and loose and you should be able to pull it out.
Old Nov 24, 2004 | 07:10 PM
shavedmax's Avatar
question answered, and well might i add. close the thread
vingodine
45
May 21, 2016 12:46 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
jomax14
Aug 12, 2015 11:49 AM
