92'vlsd,5-sp in my 91 non vlsd 5-sp???
Old Nov 25, 2004 | 12:40 PM
Yourself
wondering if i should keep this 5-sp.vlsd outta 92 se\ve ?? for my 91 5-sp.? in the (fsm-1992 ed.) vg+ve book) the bolt holes look the same for auto(vg) or 5-sp.(ve) so they are all the same prob? I bet i need the ve 5-sp and,.axles,,spindles,,computer,,linkage?,,clutch pedal + m.clyinder? ......
id prob wait till my tranny in there now crapped out but if i can keep this stuff lyin around maybe someday i could have vlsd..posi trac.?? logic tells me if i like my one wheel burnouts ....two wheels burning is twice as cool? dont get me wrong ...there will be a point when ill have an actual 92-94 se but till then upgrading my "classic se" could be fun
Old Nov 25, 2004 | 12:42 PM
internetautomar's Avatar
mod or sell?
the clutch pedal, master cylinder, and computer should all be the same.
I'm pretty sure afew people here have swapped the trannys with out swapping the pedal, computer or hydraulics
Old Nov 25, 2004 | 04:35 PM
-shock211-'s Avatar
the shift linkage, mounts, slave and master cylinder are the same.
(regarding the transmission)
the only difference between the 89-91 5spd and the 92-94 5spd.
1. obviously the differential. open diff as opposed to a viscous limited slip diff.
2. i'm pretty damn certain that the RS5F50A has a taller 5th gear than the RS5F50V. i still need to check out an 89-91 fsm to compare the gear ratios though.
Old Nov 26, 2004 | 12:59 PM
MaDMaX024's Avatar
IN for gear ratio comparison
Old Nov 26, 2004 | 01:13 PM
Cliff Clavin's Avatar
Way out West
Are you putting your LSD 5-speed into a 5-speed car or an AT car?
If you already have a 5-speed, I think the axles are the only thing that need to be changed. You might want to double check with some other guys that have put an LSD tranny in a VG car, but I think it's pretty straightforward.
Old Nov 26, 2004 | 02:35 PM
blacks92seAuto
im going to try for a 5 spd swap this spring in my 92 se...I got the ve motor...I was wondering if a 5 spd from a vg would work or would i be better getting the 5 spd from a ve, and also....what tranny should i get, non lsd, or one with lsd? Thanks and sorry to jack your thread
Old Nov 26, 2004 | 02:55 PM
Michael's Avatar
Back in a 3rd Gen.
If you already have a VE then get a 5spd from a VE. That way you will not have to change your hubs. Also although some have said that some VEs came without VLSD I havent seen one. Get a VLSD if you can.
Old Nov 26, 2004 | 03:34 PM
Bill Brasky's Avatar
Seperated at Birth?
VG bellhousing != VE bellhousing
am i rite?
Old Dec 1, 2004 | 12:16 PM
pete944/max's Avatar
Are all 92+ VE/5 spds. equipped with LSD?
Old Dec 1, 2004 | 12:34 PM
mod or sell?
they are supposed to be.
but for some reason every axle manufacturer asks if it has LSD, but LSD was supposed to be standard
Old Dec 1, 2004 | 12:37 PM
DanNY's Avatar
Ad·min·is·tra·tor
am i rite?
nope.......
Old Dec 1, 2004 | 11:32 PM
Yourself
[QUOTE=DanNY]nope.......[/QUOT
so it fits?? or ....
spencerwh1
Jun 30, 2016 05:44 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Keven97SE
Nov 1, 2000 04:50 PM
