car dies
Old Apr 18, 2001 | 01:03 PM
atulb84's Avatar
Hey. I have a 1993 Maxima SE and its been dyin alot on me lately when I'm stopped. I don't know why but i think it might have to do with the A/C or something because after i turn it on, sometimes a while later...it will just die on me. please let me know what i can do to fix it and how much it will cost. (On a good note, this is my first maxima problem i've had.)
Old Apr 18, 2001 | 05:21 PM
dmontzsta's Avatar
Ford Only.
Take it have the cat checked.That is always my suggestion after what I went threw with my car dying out...I dont even want to talk about that though.
Old Apr 18, 2001 | 08:55 PM
MadMaxBrent's Avatar
AAC valve
Could be a cause. This device bumps up the idle when accessories turn on. It may just need a clean as it can get a build up of material that comes through from the PCV valve. The AAC valve is located on the intake manifold and is easy to get at and to take apart to clean.
Brent
Old Apr 18, 2001 | 09:45 PM
superdesi's Avatar
Re: AAC valve
Brent
This is what I have noticed. When in "Drive" and stopped on a traffic light, I notice that if I use my turn signal, or turn on my headlights, my idle will drop by 100-150 RPM's. But when I turn off these accessories, it will idle around 750 RPM.
Could this be related to the AAC valve?
Old Apr 18, 2001 | 09:53 PM
AAC Valve
Yes. It could be. You should notice no discernable drop in idle when you turn on your accessories.
B.
Old Apr 18, 2001 | 09:55 PM
superdesi's Avatar
Re: AAC Valve
B.
Thanks Brent.
Old Apr 19, 2001 | 01:36 AM
Brad's Avatar
I wish i had that same conclusion to my mystery but unfortunately my torque converter was locking up and needs to be replaced, I'm sure I don't have that much longer on present tranny.
Old Apr 19, 2001 | 02:57 PM
atulb84's Avatar
could a
could a car tune-up fix all these little problems that may be causing my car to die?
Old Apr 19, 2001 | 05:04 PM
Re: Could a
It would depend upon what you get done with the tune up and the actual cause. Cars are never simple.
B.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
