No reverse lights help!!
Its easy, on a 5speed car anyway. I had to change it on my Max right when I got it.
On my Maxima, near the front drivers side of the trans(IIRC...), there is a roundish thing with wires coming off of it held in place by a single 10mm bolt.
Undo said bolt, pry out the roundish thing, and prepare to get hit with 5 quarts of foul-smelling manual trans fluid (You should replace this while you're working under here. This was also a good excuse for me to switch over to Redline fluid
Unplug old one.
Now, install the new one, put in trans fluid, and you're done! Took me no time to do the switch, but adding the fluid took quite a bit longer.
Oh, and the part was 55 bucks for me at partsamerica.com . You might want to check to see if internetautomar has em at his site for less.
)Unplug old one.
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
