O2 Sensor....?????
Old Nov 27, 2004 | 08:55 AM
nismo3366's Avatar
O2 Sensor....?????
Hey everyone...i'm hooking up my after market gauge and cant seem to get to the o2 signal wire...can anyone tell me where to tie into this???? thanks
Old Nov 28, 2004 | 07:26 AM
D-sta's Avatar
There are two ways, the right way would be to get a diagram of the ECU and find the PIN which is the o2 signal. The other way which is the lazy way is to run a wire out through the firewall through the engine bay down behind the engine into the 02 sensor itself. If I were to do it, I would just get a PIN diagram for the ECU and tap the wire there.
Old Nov 28, 2004 | 08:20 AM
nismo3366's Avatar
I already tried going under the car and trying it that way, but 2 things with that...i found a black, red, and white wire from the o2...so i tried tieing into the white one...but it didnt work...the wire from the gauge dosent reach so i used some other wire...that cauld be my problem too...i dont know...any other help plz..thanks for the respond.
Old Nov 28, 2004 | 09:37 AM
blacks92seAuto
what type of sensor you hook up to o2 sensor? is it air/fuel? and you only need to hook it up to o2 sensor?
Old Nov 28, 2004 | 07:47 PM
nismo3366's Avatar
yes its an a/f...i already have the ground, signal, and power all hooked up...but i cant find where to tie into the o2 sensor signal wire.
Old Nov 28, 2004 | 10:19 PM
blacks92seAuto
should be a wiring diagram in Chiltons im pretty sure
Doola36
Mar 22, 2015 04:39 PM
Alu Wolf
Mar 30, 2013 03:31 PM
Stagnet04
Jun 9, 2010 06:57 PM
sickspd04
Dec 19, 2008 01:03 PM
maxs4life
Sep 8, 2008 12:54 AM
