Oil Pan Bent In
Old Nov 29, 2004 | 05:49 AM
Evil_Twin's Avatar
Oil Pan Bent In
I'm finally going to do something about my oil pan. The person who owned the car before me, lifted it wrong on the oil pan, so I want to bend it out. The only way I know of taking out the oil pan is to remove my exhaust. How often do the bolts on the exhaust break off in the block? Do I even need to take off my headers to remove my oil pan? How would I go about removing it?
Thanks.
Old Nov 29, 2004 | 03:46 PM
HTPerformance's Avatar
umm.... probably just remove your y-pipe, you should be fine.
Brian
Old Nov 29, 2004 | 04:06 PM
Evil_Twin's Avatar
Guess I will do it next oil change.
Old Nov 29, 2004 | 05:54 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
why not just go to the bone yard and get a good one.....
Old Nov 29, 2004 | 06:14 PM
Evil_Twin's Avatar
I could, but then I would have to take the exhaust off on that. The closest one I know of around my house is 45mins away. I guess I could do a trip up there to check it out. I havent been to one yet.
Old Nov 29, 2004 | 06:55 PM
avmaldo's Avatar
it takes some time and can get kind of dirty good luck though.
Also make sure you don't make the same mistake when lifting the engine by the bellhousing if you don't have a hoist.
you don't have to take the whole exhaust off just detach the y-pipe. remove crossmember, alternator, gussets, etc.
Old Nov 29, 2004 | 08:24 PM
Matt93SE's Avatar
STFU n00b!
yup.. sorta what they said..
support the engine using a block of wood under the crank pulley, then pull the Y pipe, crossmember, and oil pan off. I'm not sure if you have to remove the alternator, but I'm going to guess you don't..
be sure to drain the oil first before pulling the pan!
Old Nov 29, 2004 | 08:28 PM
avmaldo's Avatar
it jus makes it a ltille easier t get to the screws for the oil pan. it's only two bolts and couple wires
Old Nov 30, 2004 | 12:16 AM
rrrfoma's Avatar
Draining oil would be a good idea
1. Remove splash pan
2. Oil
3. Remove Y-pipe (might take a long time ... really long time)
4. Remove bellhousing cover
5. Secure engine and tranny with a jack or a piece of wood - make sure that it is
6. Unbolt engine mountsfrom crossmember
7. Remove front crossmember from the way
8. Remove alternator
9. And finally unbolt oil pan
10. Have a beer or two
11. Remove old gasket with a scraper, clean it with WD40 or whatever (NOT with BEER)
12. Do whatever you need with your old oil pan
13. Apply new seal and install pan within 4-5 min (don't forget to buy a gasket kit: 2 rubber pieces and liquid sealant).
14. Install everything backwards (BTW, might be a good idea to install a new Y-pipe gasket)
Good luck!
PS: I've done this job recently ... not what I'd like to do again ...
Old Nov 30, 2004 | 06:02 AM
internetautomar's Avatar
mod or sell?
you forgot to buy a new "performance" Y-pipe
Old Nov 30, 2004 | 06:48 AM
rrrfoma's Avatar
that'd be nice ... but I'm saving some money to buy a nice set of leather seats for my truck
Old Nov 30, 2004 | 01:22 PM
icepick's Avatar
welder oh yeah
Old Nov 30, 2004 | 03:36 PM
Evil_Twin's Avatar
Well atleast I bought the rotors... heh.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
