Whirring?
Old Dec 6, 2004 | 08:32 AM
aziphrale's Avatar
Whirring?
I wrote a thread previously about a whirring that i hear when I hit the gas... Its back again. i have no idea what this can be... I have checked for loose hoses and things of that nature and no luck. People said exhuast studs. But i dont think that that is it being that this is a new engine does anyone have an idea what this could be? It happens when i hit the gas at a light or in traffic off a stop. It will start when i let off the gas and press again it doesnt make the sound anmore. this was not happeneing before in the summer. Someone
Old Dec 6, 2004 | 08:33 AM
DanNY's Avatar
Ad·min·is·tra·tor
total guess...wheel bearing? tranny problems?
Old Dec 6, 2004 | 08:35 AM
Greeny's Avatar
¯\(°_o)/¯
Power steering pump whining???
Old Dec 6, 2004 | 08:50 AM
aziphrale's Avatar
In July of 04 i got new engine and tranny put in ... the tranny and engine run like a champ. it sounds like its coming form the passenger side of engine bay... Isnt the power steering on the drivers side?
As Far as the wheel bearing goes. I also changes lower ball joints about 2 mnths ago... bought them off the net. They are bad i hear sqeaking now i learned my lesson..straight dealer now on suspension parts.
Old Dec 6, 2004 | 08:52 AM
Greeny's Avatar
¯\(°_o)/¯
Yup..........
Old Dec 6, 2004 | 09:52 AM
DanNY's Avatar
Ad·min·is·tra·tor
Originally Posted by MyGreenMax94
Yup..........
try again.
PS pump it on the pass side w/ the belts.
Old Dec 6, 2004 | 09:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
ball joints are not wheel bearings.
new engine and tranny...rebuilt units i assume?
Old Dec 6, 2004 | 09:58 AM
aziphrale's Avatar
Tranny was a rebuilt from another car and the engine was a direct import from Japan. Had about 64k It was cleaned and whatever needed minor things was also done. I think that i also got power driving replaced during summer when engine was put in...Cant remember ill check paperwork. Also so the wheel Bearing can cause this? No work was done to steering anything. i would like to check it out if possible.
Old Dec 6, 2004 | 10:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
ok so i wouldn't say the engine was new at 64K on it.
also i wouldn't consider the tranny as being new because it's a rebuilt.
when you say NEW it throws me off on what might be wrong.
wouldn't hurt to check steering...if you want remove the PS belt and drive a little (i stress a little) and see if you hear it..but i some how doubt it's the steering because you only hear the noise when you hit the gas. if it's the PS pump then you'll hear it all the time or when you turn the wheel...doesn't matter when you hit the gas. also check if they replaced the belt tensioners when the motor was swapped out.
Old Dec 6, 2004 | 10:24 AM
Greeny's Avatar
¯\(°_o)/¯
try again.
Sorry,just woke up didn't fully read the post...
Old Dec 6, 2004 | 10:31 AM
DanNY's Avatar
Ad·min·is·tra·tor
no prob...it's monday...
PH98I30
19
Jun 13, 2016 02:38 PM
Vequity
Sep 10, 2015 05:26 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
boba001
Apr 20, 2004 02:34 PM
