Brake Fluid Leak
Old Dec 12, 2004 | 09:23 PM
Vadim-93GXE
Brake Fluid Leak
My brake fluid has been leaking for sometime now, and I recently diagnosed the problem. Whats that ABS Unit thing called with the tubes coming out of it to the left of the radiator. I heard its expensive. Thanks.
Old Dec 12, 2004 | 09:25 PM
Jeff92se's Avatar
I'm needing a caw
It's called an ABS unit(actuator). Read though the threads and look in the stickies for more info.
Old Dec 13, 2004 | 03:11 AM
Wiking's Avatar
Wash it and pinpoint the leak. Maybe its just the tubes loose? [old car, 'every thing needs tightening] If broken, I would rebuild or buy used assy.
Old Dec 13, 2004 | 08:33 AM
Vadim-93GXE
Hard to explain but it seems it's leaking right where the two peices come together. So I tried tightening the screws, thought maybe it would slow down the leak, but obviosly it doesn't have a proper seal. So how much you think it would go for at a junkyard? And how would I know if it's good or not? They may wipe it nice and clean before they sell it to me.
Old Dec 13, 2004 | 08:42 AM
DanNY's Avatar
Ad·min·is·tra·tor
ask for a warranty.
Old Dec 13, 2004 | 09:50 AM
Wiking's Avatar
I would guess that it most obviously has had an excellent seal. Now 11 yrs old, hardened dry in an very hostile environment jumping "continuosly between -40 to +200." Or there's some mfg defect.
If you can tighten it, you can also open it. Clean it thoroughly and open in clean environment. Maybe there's a rubber seal you can replace? If so, its made of special stuff. The question is to wise men on this forum, where one could find pics & ABS spare parts?
Anyway, brakes are mostly useless but tend to be critical few times in a lifetime... So better to know precisely what/how u do. Cleanliness is must1.
Old Dec 17, 2004 | 05:22 PM
Vadim-93GXE
So is the ABS Actuator the same on the GXE as the SE? T
Old Dec 17, 2004 | 08:19 PM
whitemax28's Avatar
check the master cylinder also
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
The Wizard
24
Oct 1, 2015 08:47 PM
bbsitum
Sep 11, 2015 04:55 PM
ag90fox
Sep 9, 2015 12:22 PM
