How did you wire your gauges...
Old 12-20-2004, 05:36 PM
Evil_Twin's Avatar
How did you wire your gauges on the triple pod pillar gauge? Where did you run your wires through the firewall?
Thanks.
Evil_Twin is offline
Old 12-21-2004, 08:24 AM
Evil_Twin's Avatar
Like where exactly did you wire your wires through?. Is there a hole I can go through?
And what color is the signal wire on the O2 sensor?
Thanks.
Old 12-21-2004, 09:00 AM
HTPerformance's Avatar
I have yet to hook up the A/F wires, but I can tell you that If you remove the inner fender lining of the drivers side front you will see a rubber boot (grommet) with the large wiring harness going thru it, a perfect place to go thru. The 02 sensor you are better off tapping at the ECU harness.
Brian
HTPerformance is offline
Old 12-21-2004, 09:16 AM
Ad·min·is·tra·tor
DanNY's Avatar
what gauges do you have?
evil twin the forum has an edit function so you can edit your thread instead of posting again.
DanNY is offline
Old 12-21-2004, 02:09 PM
nismo3366's Avatar
I tried hooking up my a/f ratio wire and even posted here for help, someone told me to tap into the black on ( messed up my car) , then i tried the white( didnt do anything) so i dont know...i still need more help on how to hook it up.
nismo3366 is offline
Old 12-21-2004, 02:31 PM
goon9's Avatar
oh god..... Black is ground.
goon9 is offline
Old 12-21-2004, 02:38 PM
MrGone's Avatar
I cant remember if this is for both cars or just the VE or what but...
Mines still tapped from the last gauge (at the wiring harness at the ECU).
I'll run the EGT and any other wires through the hood release cable gromet. Volts is easy, and O2 I'm probably not even going to bother hooking up.
MrGone is offline
Old 12-21-2004, 03:40 PM
Evil_Twin's Avatar
DanNY. I know theres the edit button, but I figured if I edited it nobody would see it cuz it wouldn't "bump" up.
1989MaxMan - How do you remove the inner fender lining?
Old 12-21-2004, 03:55 PM
KLoWnPR109's Avatar
undo the screws and pop it out
KLoWnPR109 is offline
Old 12-21-2004, 04:16 PM
Along the fender there are 6-10 screws? and a few inside the fender. then pull out the plastic.
Brian
Old 12-21-2004, 08:54 PM
GRNMAXDMON's Avatar
MrGone if i remember correctly i think that schematic is for the VE not VG u tried helping me on this awhile back but i could be wrong.
GRNMAXDMON is offline
Old 12-26-2004, 10:40 AM
Evil_Twin's Avatar
so on a VG engine, what wire do I tap into through the ECM for the air to fuel ratio gauge?
Edit: Guys I finally got it. For you VG guys, it's the same thing. I've been researching alldatapro for like a couple days. Here's the lay out though.
I hope thats big enough for you guys
trsandrew
04-08-2016 06:45 PM
doctorpullit
03-29-2016 11:08 AM
trsandrew
10-25-2015 02:47 PM
Kyle Lee Cleveland
09-28-2015 09:03 AM
Quick Reply: How did you wire your gauges...
