winter preparation
Old Dec 21, 2004 | 11:14 AM
whitemax28's Avatar
winter preparation
this is for anybody that knows, do you need to do anything particular to get your max ready for the winter. Thanks
Old Dec 21, 2004 | 11:18 AM
internetautomar's Avatar
mod or sell?
park it in the garage and take out the 4x4
Old Dec 21, 2004 | 11:20 AM
whitemax28's Avatar
LOL, no really
Old Dec 21, 2004 | 11:28 AM
Bman's Avatar
Just prepare like you're going on a long trip... fluids, tire pressure, etc. Ice scraper. An emergency kit and shovel in the trunk wouldn't hurt either.
I don't know how much snow your part of NY gets, but snow tires would usually be worthwhile too.
Old Dec 21, 2004 | 11:33 AM
MrGone's Avatar
1. fix heater
2. fix rear defroster
3. get up early and scrape
well for me anyway I've only gotten to number 3
Old Dec 21, 2004 | 11:44 AM
whitemax28's Avatar
cool, thanks bman and gone
Old Dec 21, 2004 | 11:50 AM
alpicone's Avatar
Does anybody do any sort of rust proofing for the winter. Like spraying oil of the underside of the car?
Old Dec 21, 2004 | 11:52 AM
Jeff92se's Avatar
I'm needing a caw
Don't crash.
Wiking's Avatar
4. Gear for ten mile cross c ski in -40 [ECU starts thinkin]
5. 20ft Rope [giveout]
6. Mini gas heater [cook hot water in snowstrom]
7. Grinded Axe [if wikings invade]
MAXIMA is a HOT CAR!
Old Dec 21, 2004 | 11:54 AM
Wiking's Avatar
Originally Posted by alpicone
Does anybody do any sort of rest preoofing for the winter. Like spraying oil of the underside of the car?
Thats what we do for the sleds, reindeer oil... and besides, all ol maximas have that feature automatic.
Old Dec 21, 2004 | 01:06 PM
aziphrale's Avatar
Originally Posted by MrGone
1. fix heater
Does anyone know if the 89 gxe. Has a rear defrost?
Old Dec 21, 2004 | 01:07 PM
MrGone's Avatar
should, and its the button to the far right on the peice below the gauges, kind of next to the hazard button.
bhunter's Avatar
8. Rainex the windshields
9. Top off antifreeze or even flush cooling system
10 Steal electric heater from old drive-in movie (forgot, you're all too young!!)
Old Dec 21, 2004 | 01:13 PM
aziphrale's Avatar
Yea well then i dont think mine is working. Its the button with the heat coming up and it turns orange when you press it? When i have it on. The rear doesnt seem to clear up at all. I also put my hand to feel if air is coming up and also its not. I have no idea. do you have to have it on with another button as well maybe? I see it has vents in back but someone on here told me that thats for when you close the doors the air can escape. :sigh:
Old Dec 21, 2004 | 01:14 PM
MrGone's Avatar
I've been meaning to rainex the windows
ohhh i should check it, even though i know its good, never hurts. I also should top off the windsheild wiper res.
(forgot, you're all to young!!)
true story
Old Dec 21, 2004 | 01:32 PM
alpicone's Avatar
It doesn't blow. It is electric. You see those lines on the window, That is your defroster.
Old Dec 21, 2004 | 01:36 PM
aziphrale's Avatar
It doeant blow. It is electric. You see those lines on the window, That is your defroster.
ugh ? Lines in window...? ugh. Which way did he go. Which way did he go george.
Old Dec 21, 2004 | 01:37 PM
Jeff92se's Avatar
I'm needing a caw
haha! I knew immediately where that line was from.
Old Dec 21, 2004 | 01:45 PM
MrGone's Avatar
then what is that vent peice for? (I know its the lines, but I just thought about that) strange
Old Dec 21, 2004 | 02:01 PM
alpicone's Avatar
It is to vent out the car. The air comes through the front vents, goes out the rear vents under the window, and out of the vent in the trunk (drivers side behind the carpet on the bottom).
Old Dec 21, 2004 | 02:11 PM
MrGone's Avatar
cool
Old Dec 21, 2004 | 08:00 PM
fred's Avatar
hey what is an easy fix if some of those lines dont work..i.e. they dont defrost
Old Dec 21, 2004 | 08:08 PM
nelledge's Avatar
"I'm just sayin'..."
If all the lines don't work, look for a break somewhere on the problem line(s). Part stores sell a liquid repair kit. Some people can get it to work, some can't. It's worth a shot for about 5-6 bucks IMO.
Old Dec 21, 2004 | 10:38 PM
Wiking's Avatar
Measure the broken win wire resistance with dmm to find that cut location.
Once in a lifetime soldered them with thin wire. Works on some, on others tin does not attach.
bhunter :
11. Throw the heater out as its dead [get arrested]
12. Silicon spray for door seals [not to freeze-rrRrip]
Old Dec 22, 2004 | 12:20 PM
fred's Avatar
ok thanks guys
Old Dec 22, 2004 | 01:16 PM
Loe max's Avatar
I deflate my tires from the normal 35psi all around to 29psi.
Old Dec 22, 2004 | 04:34 PM
Cliff Clavin's Avatar
Way out West
I have four studded snow tires mounted on steel wheels ready in the garage. When the weather forcaster says "snow" I go out in the garage and install them. I had them on for a week when we had heavy frost, but took them off again. By the sounds of the forecast, I will likely be reinstalling them next week.
I also put the ice scraper in the jockey box and I try to keep my gas tank above 1/2 at all times.
Old Dec 22, 2004 | 04:47 PM
blacks92seAuto
1. fix heater
like 4 of my lines on my rear window dont defrost but the rest do...how can i fix this, my window is tinted........
Old Dec 22, 2004 | 04:58 PM
MaximaBalla's Avatar
Same thing happened to me with the lines on my window too I think. Lucky for me, it's just the top two lines. So, I think they're really not worth it to fix since they don't defrost an important area. I can still see perfectly fine with them not working.
Old Dec 22, 2004 | 10:41 PM
Wiking's Avatar
Studs fly if gas pedal is digital on/off flip flop -type... Its precision sync driving as one brakes only when all your studs are down... The wide tyres are extra bad on snow, dont like that winter feature.
By law we must have em four months a year.
I installed extra shield under the tranny to keep it from wind, also have shield in front of grille for the cold days -10 or so...
Old Dec 22, 2004 | 11:18 PM
usmanasif's Avatar
Mr. whitemax28, I have a question for you. Why are you asking about winter prep AT THE END OF DECEMBER? You may have missed the bus already.
Just scratching my head, that's all.
Old Dec 23, 2004 | 12:41 AM
Maxzilla91's Avatar
i think the best thing u can do is park it indoors. i'm lucky to be able to park mine in the garage.
and warm up ur car before u leave? or are we supposed to do that on warm days too? it ain't that cold here in vancouver. so i hardly do any of the stuff mentioned.
Old Dec 23, 2004 | 05:49 AM
Wiking's Avatar
13. Cut the flaps.
(Dunno general US accessories: Scandics have mud ?"flaps"? behind the wheels) They're supposed to be nice, forming a black cup [geisha china -design?]. This is also ? to maximize maxima scooping effect.
Every time u get into the garage with ton on snow [there!], garage will be a swamp next 24hours. Cutting the lowest edge which is bent forward, some snow flakes have at least a chance to drop off while driving...
Old Dec 23, 2004 | 05:58 AM
rimmer1's Avatar
14. jumper cables - thick ones
15. lots of blue juice
16. safety bag i.e - gloves, hat, etc
17. tow rope
18. CAA
today is a bomy -20 with 1 foot of snow and expecting another foot
snow for the fat man
Merry Christmas Maximafanactics
Old Dec 23, 2004 | 08:14 AM
wpgmax's Avatar
It was -48 degree's celcius when I went to work this morning. (that's -54.4 Fahrenheit). Was a wee bit cold.
Old Dec 23, 2004 | 08:24 AM
LMaRiE91MaXiMa's Avatar
The rear defroster doesn't have "air" blowing on it like the front does, there arent any real "vents" in the rear (not on my car anyway - a '91). The rear defroster are all those black lines on the rear windshield itself!! The button you are describing is in fact the rear defroster button. There's a little "heat waves" on the button itself and it does light up a little orange light in the middle of the button when turned on. Sounds like your defroster just plain doesnt work...i would suggest leaving windows open in the back at least a crack..that way it will help defrost it somewhat...until you take it to a garage to get repaired!
Old Dec 23, 2004 | 08:28 AM
I was told to ALWAYS let the engine warm up before leaving, ESPECIALLY in winter. You have to give it time to warm up the oil, and let the oil thin out and work its way into all the parts of the engine...Otherwise, all your oil is settled at the bottom and very thick (when cold) and if you start driving, you'll be grinding all the metal parts together because they aren't yet properly lubricated. They say thats one of the worst things you can do to your car (drive it when its cold)...not to mention you can crack a lot of stuff in there because of the sudden heat from the gas burning against these freezing cold parts = major crackage!
Old Dec 23, 2004 | 08:31 AM
My top 2 and bottom 2 rear defroster lines dont work either , but the middle does so I'm not worried about it either - as long as I can see fine too I'm ok...
But if it is cheap to fix that, I'd look into it...
Old Dec 23, 2004 | 09:03 AM
mod or sell?
chances are your lines are just broken at some point.
go find permatex part # 15067 and that will fix the broken lines
Old Dec 23, 2004 | 09:45 AM
Wiking's Avatar
Originally Posted by LMaRiE91MaXiMa
...time to warm up the oil, and let the oil thin out...
- Buy synthetic, always perfect viscosity.
- Defroster - permatex, yes, will try that, soldering is too tri c k y.
19. Volvos have heated steering wheel, who will swap? Volvo = the swedish tractor.
