car is running, but now overheats like CRAZY! Help!!!! ASAP!!
Old Dec 21, 2004 | 03:55 PM
coreyblade's Avatar
Ok i just got it back up and running, and now im having the same problem with it as before. its over heating, except now more then ever, i replaced the thermostat, water coolant temp sensor, radiator cap and it has plenty of fluid.
its getting all the way up to the top on the hot thing.
What could be the problem?
the oil is NOT milky colord either.
i test drove the car, got about a mile away from the house and it started over heating and go to the point where i pulld over and parked it and jogged all the way home.
Old Dec 21, 2004 | 04:05 PM
Bill Brasky's Avatar
Seperated at Birth?
antonthegrey: from what you're telling me, you most likely have an air bubble in the coolant which isn't allowing your thermostat to open.
antonthegrey: leave the cap off, run the heater on full, and all the way hot
edit: aim log = b7
Old Dec 21, 2004 | 04:19 PM
Cliff Clavin's Avatar
Way out West
Sounds like you got some exercise in today...
have you ever replaced your water pump?
Old Dec 21, 2004 | 04:29 PM
Jeff92se's Avatar
I'm needing a caw
Have you??
Old Dec 21, 2004 | 04:45 PM
Seperated at Birth?
Originally Posted by Jeff92se
Have you??
not something i want to do... even on a VG....
gimme a SBC and I'll do water pumps all day long
edit: that's not the only pumping all do all day long!
AYYYYYYYYY OOOHHHHHHHH!
Old Dec 21, 2004 | 05:02 PM
coreyblade's Avatar
where is the water pump located on a Vg30e?
how hard is it to change/?\
what kind of price are we talking about.
Old Dec 21, 2004 | 05:07 PM
Seperated at Birth?
Attention all Org'ers, attention all Org'ers! Will Internetautomar please report to this thread for customer service? Again, will Internetautomar please report to this thread for customer service. Customer is waiting. Thank you.
Old Dec 21, 2004 | 05:15 PM
Greeny's Avatar
¯\(°_o)/¯
LOLOLOLOL!!!!
Old Dec 21, 2004 | 05:42 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
ill second the LOL..
there should be a "bolt" that when loosened on the intake manifold acts as an air bleeder for the coolant. i kow the ve has it youll have to ask if the vg does
Old Dec 21, 2004 | 05:50 PM
whitemax28's Avatar
doesnt your max have a VE motor it being a 92??
Old Dec 21, 2004 | 06:16 PM
4dscPat's Avatar
nope, it's a GXE, all 89-94 GXEs have the VG.
Old Dec 21, 2004 | 06:23 PM
alpicone's Avatar
Ya, try opening the bleeder valve to let out the air. Open and let the car run until coolant start coming out of it. Then all the air is out.
Old Dec 21, 2004 | 06:30 PM
coreyblade's Avatar
where is the bleeder valve on a vg. ive never herd of that. or know where to look.
btw there are alot of "bolts"
Old Dec 21, 2004 | 06:33 PM
alpicone's Avatar
It is on the top of the intake manifold. If you are looking from the front of the car it is on the back right hand side, right in front of the PCV valve.
Old Dec 21, 2004 | 06:34 PM
coreyblade's Avatar
uhhhhhhh? *confused*
Old Dec 21, 2004 | 06:53 PM
internetautomar's Avatar
mod or sell?
2 things:
1. is the thermostat in the correct way? (not sure if you can put it in backwards or not)
2. start the car with radiator cap off and watch to see if the coolant starts to move, if it does then the water pump is good or at least semi-functional, if it doesn't then you have a problem.
BTW wait til the car warms up a bit to look for movement.
Old Dec 21, 2004 | 08:19 PM
Chris Gregg's Avatar
Get Off My Lawn
Personal experience: My Max has had a slow leak at the water pump for almost two years. Just yesterday I had to park my Max due to it overheating. I believe my waterpump has just crapped out. So do check waterpump. The other alternative, you state that the coolent has no appearent oil in it. I owned a GrandAm that had a sealed coolant system. It kept overheating, turned out to be the headgasket. Draining the coolant, there were traces of oil which were not noticeable with the fluid in the car.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JMag90
Aug 25, 2015 09:17 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
