tranny questions? Tranny trick?? In auto vg?
Old Dec 21, 2004 | 01:59 PM
whitemax28's Avatar
tranny maintenance
we all do oil changes every 2500-3000 miles. Is there a regular thing we have to do regularly with the tranny maintenance wise?
Old Dec 21, 2004 | 06:23 PM
internetautomar's Avatar
mod or sell?
from new, I'd recommend every 25k. if not then change fluid when it is no longer red.
Old Dec 21, 2004 | 06:26 PM
alpicone's Avatar
I do my tranny fluid once a year. It may be overkill but tranny fluid is cheap and easy to change and a new tranny is expensive. The last time I did it I took out all the old fluid by disconnecting the return line from the radiator. After I did this the hard 1-2 shift that I would get sometimes is gone (watch it come back tom).
Old Dec 21, 2004 | 06:28 PM
coreyblade's Avatar
how do you change the fluid in a tranny on a vg30e auto?
Old Dec 21, 2004 | 06:32 PM
alpicone's Avatar
There is a plug on the bottom that you open up and drain the fluid. Cant change the filter on these trannies, just drain and refill.
Old Dec 21, 2004 | 06:36 PM
coreyblade's Avatar
whats the best kind of fluid to use? and how much do i put in?
Old Dec 21, 2004 | 06:37 PM
whitemax28's Avatar
thanks man
Old Dec 21, 2004 | 06:55 PM
mod or sell?
you put in regular old dexron III or equivelant.
the amount needed I don't know though the FSM should say in the maintenance section
Old Dec 21, 2004 | 07:14 PM
coreyblade's Avatar
"""""""The "tranny trick" is a modification that involves the simple pulling of a wire harness that resides near the left strut. When you pull the connector, it takes out the line resistance that makes the shifts soft in an automatic transmission Maxima. I have heard both good things and bad things with this "trick" and use it very seldom."""""
Quote from a website
how do i do the trick and what does it do? And is it safe?
how much fluid do I need to put in a auto vg tranny after flushing it.
also how much will getting a vg tranny rebuilt cost on avg?
Old Dec 21, 2004 | 08:06 PM
DanNY's Avatar
Ad·min·is·tra·tor
1 - not safe at all...it makes the tranny shift at full fluid pressure...which will slam the gears. a weak tranny will turn to a dead tranny very quickly.
2 - i think it's like 2-3 quarts for a drain and fill...a "flush" is i believe 10-12 quarts.
3 - anywhere from 1000-3000....YMMV.
Old Dec 21, 2004 | 08:11 PM
GRNMAXDMON's Avatar
for the drain and fill is 4 quarts but for a complete flush is about the amount of what DanNy says as well for the average price in a auto rebuilt which sucks a$$ after it is rebuilt cuz it won't be the same after that so don't do any tricks to ur tranny if its auto. our maximas r prone for auto trannies getting messed up.
Old Dec 21, 2004 | 08:24 PM
coreyblade's Avatar
well whats the difference in a flush and a drain. whats the best way to do either of them and can i alone do either of them. I know its time to change the fluid for sure.
whats the best way to go about doing this. I just need to know EXACTLY how much fluid i should buy and put in there. I dont want to not have enough or to have too much. Also my dipstick is gay on my tranny so there is no way in hell to tell if its low or high.
Old Dec 21, 2004 | 08:30 PM
LvR's Avatar
LvR
First buy a dipstick that works and only then do the oilchange thing.
Old Dec 21, 2004 | 08:33 PM
GRNMAXDMON's Avatar
a drain and fill is like ur changing ur oil in the motor except that the tranny oil travels into the radiator to cool down so when u do the drain and fill ur not draining the oil thats already in ur radiator so thats gonna be there and ur oil is gonna get dirty and black again. when u do the flush is basically draining all the tranny fluid out by putting in fresh fluid in then i believe u start the car so that the oil circulates and then turn it out after about 2 min. now i may be wrong about the method of flushing so u would have to use a Haynes or Chiltons service manual and it will tell u how to do this. its been awhile since my car is now converted to a 5-speed. well after u turn off the car drain the fluid again and then put fresh fluid again. remember ur car has to be turned on while measuring how much fluid is in ur tranny with ur dipstick. the fluid should be on the top 2nd notch of ur dipstick while the car is on though and that will tell u that u have enough fluid.
now to make my point i would do the flush since ur gonna have fresh fluid in the whole tranny rather than havin' to do the drain and fill cuz ur still gonna have old fluid in mixed with fresh fluid and if ur mechanically inclined u can do it on ur own.
Old Dec 21, 2004 | 08:40 PM
DanNY's Avatar
Ad·min·is·tra·tor
listen to this man
Old Dec 21, 2004 | 08:46 PM
GRNMAXDMON's Avatar
Originally Posted by DanNY
listen to this man
yes listen to him.
Old Dec 21, 2004 | 09:31 PM
coreyblade's Avatar
thanks a bunch GRNMAXDMON. I change my oil myself every 2,500miles.
also i might just take it to somewhere and get the tranny flushed. sounds like too much pain the a$$ crap. I dont have time to fool with it. Id rather take it somewhere and have it done for like 20$.
Old Dec 21, 2004 | 09:32 PM
eric93SE's Avatar
I run royal purple syn atf.
Old Dec 21, 2004 | 10:14 PM
LvR's Avatar
LvR
also i might just take it to somewhere and get the tranny flushed. sounds like too much pain the a$$ crap. I don't have time to fool with it. Id rather take it somewhere and have it done for like 20$.
In which case its going to be an even bigger pain in the a$$ - if the guys know what they are doing, they will refuse to change the oil for as long as they cannot determine the correct current level of the fluid after a refill - either way, you gonna have to get a working dipstick, and no dipsh1t worth his salt will change the oil without it - so choose how much you really want the oil-change to cost you - dipstick and oil or new tranny?
Old Dec 22, 2004 | 06:29 AM
DanNY's Avatar
Ad·min·is·tra·tor
yes you can!
Old Dec 22, 2004 | 06:36 AM
alpicone's Avatar
yes you can!
Okay let me rephrase that. You cant change the filter without removing the tranny and cracking the case open!
Old Dec 22, 2004 | 06:38 AM
yelowd's Avatar
Does the filter need to be changed?
Old Dec 22, 2004 | 06:43 AM
DanNY's Avatar
Ad·min·is·tra·tor
you change THAT filter in the pic when you rebuild. most shops would just clean it out unless you had a massive failure in the tranny.
Old Dec 22, 2004 | 06:54 AM
mod or sell?
tranny services are normally in the $40 on up range at most places.
Old Jan 2, 2005 | 03:55 PM
Ramiro U's Avatar
hello guys im about to replace my solinoids on the tranny has anybody ever replaced them here in if so did it work ???
Iv'e had it rebuilt 2 time in 2 years this is my last atempt to fix it before I buy a used tranny from one of these japanese importing companies $850
Old Jan 2, 2005 | 04:38 PM
4dscPat's Avatar
The only thing most people do regularly to 3rd gen auto trannies is rebuild them.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
Lowered_a33
Sep 1, 2015 07:49 PM
