My Engine Looks Like C**P
I want to know if you guys Clean your engine bays, and if so How? I figuered if you spraid any sort of water in the engine there could be consequenses.
My engine is all grimey and looks like steam stains. Replaced the radiator because of it, but the air intake manifold is stained. How can I Clean the engine bay? any suggestions would be greatly appreciated.
do what i did. swap a jdm ve in there....while its out, clean the shiit out of it. and clean the engine bay. then put that badboy in there. and walla, nice looking engine bay with a 30-60k motor...or you can just not worry about as long as it runs good.
Originally Posted by Slamnasty
I have those fears myself. But I have a friend who used to be a mechanic and he does it all the time to his 93 Honda Accord SE, and to other cars he's had, so I guess it's no biggie. :shrug:
I use all purpose cleaner and engine cleaner spray it on pretty much everything cept the alti. and coilpacks and fuse boxes etc.. then I let it sit than power wash it than dress all the plastic and rubber and call it a day.
Has any one else done this before? Im doing a Tune up this Saturday and While I was at it would Clean the Engine bay, but dont want to do somthing that would make the car stop runny.
N34JZ and you do this all the time right
Originally Posted by blacks92seAuto
he does what all the time? only thing suggested so far on this thread is simple green and going to town
He even did it to an old 87 Z24 I used to have, and no problems resulted.
Well, "all the time" meaning 2, *MAYBE* 3 times a year at the local DIY wash. He doesn't do it everytime he pops the hood or cleans the car.
you said...
yes every car I detail I use the same procedure, why would I do it if it would mess up my car? Your not gonna mess up your engine, if youve got a VG just cover the distributor.
Having a open element filter tends to up the difficulty scale ever so slightly. That is if you don't have a CAI . I would like to have the engine running while I am rinsing it with water just so that I can stop when the engine starts to heave. But what I have always done is cover my K&N with a plastic bag, soak the engine bay with Simple Green, let it soak (the longer the better, unless your engine is hot, but still doesn't make much of a difference,) and rinse it off with high pressure at the car wash. I have never had an issue. Of course I don't hold the 90psi over my distributor, cover or not.
-Sean
shilov
02-19-2024 09:40 PM
James92SE
142
01-02-2024 09:23 AM
