sizing
Old Apr 22, 2001 | 09:20 PM
mymax93's Avatar
i have 205/55/16's right now, i wanna switch to 215 or 225/50 or 45/16's, are there ne negative effects from that? also does that mess up ne thing with correct mileage or speed?
Old Apr 23, 2001 | 07:47 PM
Chris Gregg's Avatar
Get Off My Lawn
You're right about probably having to decrease tire size due to increase in tread width. I assume that the wheels are 16x7 or 7.5, so the 225x45 would look really good.
Old Apr 23, 2001 | 08:53 PM
Matt93SE's Avatar
STFU n00b!
215/55 and 225/50 are the "correct" sizes for our cars. just make sure your rims are wide enough for the 225s if you go that way. they need to be at least 7" wide. any narrower, and I would say to stay with the 215/55.
No, you won't have to adjust the speedo or anything with these sizes. if you use the 225/45, you'll have a slightly smaller tire than you should, causing your indicated speed to be a small fraction higher than you're actually going.
Old Apr 24, 2001 | 04:39 AM
Pervis Anathema's Avatar
F.Y.I, in the links section under automotive technology? there is a tire size calculator. Very useful little applet.
Old Apr 24, 2001 | 11:29 AM
mymax93's Avatar
they are 16x7's , if i put on 225/45's would that take away too much meat on the tires?
Old Apr 24, 2001 | 12:55 PM
Matt93SE's Avatar
STFU n00b!
the outer tire diameter will be slightly too small, causing your speedo to be off and an even bumpier ride than you already have.
Old Apr 24, 2001 | 01:09 PM
mymax93's Avatar
so the best thing would be to go with the 215/55's?
Old Apr 24, 2001 | 01:50 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Do you need......
to run spacers with the 225's? when I tried to fit some 225's on last summer it was real tight, so I was afraid of rubbing and I just took them off since it looked like it would rub on the rear suspension. as for the fronts they seemed to fit fine. but since I plan to get either Suspension Tech spring or Spints this summer, I was wondering if that would make fitting 225's even more of a prob with or without spacers??
Old Apr 24, 2001 | 08:12 PM
Matt93SE's Avatar
STFU n00b!
depending on the wheel, you can use 225/50 without problems. 215/55 are also fine..
225/45 are too small.
If 225/50 are okay with stock springs, it won't change with any other springs on the back.. the geometry in the resr suspension is changed at the top of the strut, not between the strut and spindle.
Old Apr 24, 2001 | 08:44 PM
superdesi's Avatar
Where?
Old Apr 24, 2001 | 09:14 PM
DA-MAX's Avatar
Its on....
the LInks [age on thw Maxima.org start-page, but heres the site--> Click!
Originally posted by superdesi
Where?
Miket2006
Mar 1, 2021 03:55 AM
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
knight_yyz
Nov 1, 2015 01:34 PM
