Strange door lock problem
Old Jan 5, 2005 | 10:20 AM
Brad92SE's Avatar
Hey guys, I am having a really wierd and annoying problem with my locks. 90% of the time when I turn the ignition off, the doors will lock. Then when I try to unlock them, they will unlock then lock back up, as if the door were open. The will do this a few times, then finally staying unlocked. After that though, they will only lock when I press the unlock button, the lock button does nothing. I assume this has something to do with the door lock timer, but I just re-soldered all of the connections on it (the problem was happening before that). Has anyone had a similar problem, or have any ideas? Thanks!
Old Jan 5, 2005 | 10:59 AM
Wiking's Avatar
Sounds logically illogical. Have you checked voltage level: bad +12V supply, gnd, -o-r- smtg overloading your logic.
- Tst disconnect other doors from the circuit.
- Tst take alarm fuse out.
- Any changes?
- hmm.
Old Jan 5, 2005 | 11:15 AM
-shock211-'s Avatar
hrrmmphhh...
that's an odd one brad. i can't even think of where to start.
to me it sounds like either a relay or short somewhere in the wiring between the steering column and the door lock timer.
Old Jan 5, 2005 | 11:20 AM
bhunter's Avatar
Maybe a problem with the keypad on the driver's door?
Old Jan 5, 2005 | 11:24 AM
Jeff92se's Avatar
I'm needing a caw
I have a similar problem. When I try to unlock the car using the key, it will unlock and them immediately lock again. Happens mostly when it's cold.
Old Jan 5, 2005 | 12:05 PM
citadel07's Avatar
same here jeff it sucks.....especially when your tryin to unlock the door for your girlfriend and it keeps locking on you. feel retarded. anyways i thought it was probably grounding out somewhere just havent had time to trace it. be sure to post back or pm me if u figure it out.
Old Jan 5, 2005 | 12:16 PM
-shock211-'s Avatar
jeff & citadel07,
just spray the lock with a graphite lock lube. i had the EXACT same problem and it's completely gone now. depending on how cold it gets you may need to do it once or twice a month in each key hole.
Old Jan 5, 2005 | 12:52 PM
citadel07's Avatar
ok thanks i'll try it out....
Old Jan 5, 2005 | 11:29 PM
Wiking's Avatar
Originally Posted by -shock211-
jeff & citadel07,
Was it your aunt's home lock?
Electronic problem will not vanish via lockspray. Its still good to have them lubricated, but with wireless, locks are not even needed.
Btw. The drivers lock switches might be out of alignment, sw or wires broken.
Old Jan 6, 2005 | 06:46 AM
-shock211-'s Avatar
i don't have an electrical problem with my door locks like what brad is describing.
but like it was described by jeff and citadel, when the weather is cold and you try to unlock the door with the key, it tends to just lock itself back up. why?
i don't know but i did spray some lock lube in and it hasn't happened in the last month or so.
Old Jan 6, 2005 | 07:15 AM
Wiking's Avatar
The lock is dead metal, not capable on anythin but jamming, resisting you... The locking is actuated by solenoids, that needs electricity. There is a microswitch 'sensing' u lock lever position. Worn, ? needs adj., alarm system or door ctrl berserk of cold, ctrl wires pinned, logic supply voltage low because of oxidation... please see my web page on electricals...
http://www.cardomain.com/memberpage/748507/1
Why tsunami? One day the door will not be a problem as u car will not start, maybe next again it will.., why is that? Lack of Maintenance. These luxury cars need tremendous amount of work to keep all features running. If one does not do that tedious PM work, one maybe gets a car with only 10% features Maxima has got.
Basically: that which is not there will never go kaputt...
Old Jan 6, 2005 | 11:34 AM
MrGone's Avatar
Same thing happens to me Jeffy. It isn't consistant, just every now and then I'll unlock it then it locks and kind of twists the key wierd. Also when it first started getting cold my ability to unlock all the doors from the driver door (with the key) stopped working.
I just want to get a keyless entry now
Old Jan 6, 2005 | 11:52 AM
-shock211-'s Avatar
when'd you become a moderator shawn?
Old Jan 6, 2005 | 12:25 PM
MrGone's Avatar
today
Old Jan 6, 2005 | 12:32 PM
Loe max's Avatar
I was locked out of the car last night for this reason.
Old Jan 6, 2005 | 12:53 PM
DennisMik's Avatar
I also have Jeff's problem, but most of the time when this happens, I turn the key in the locking direction first and then the door unlocks and stays unlocked. My keyless entry pad always unlocks the door on first try.
Old Jan 6, 2005 | 02:16 PM
Loe max's Avatar
Come to think of it, my dads 91 does the same thing. When I came back from lunch today, I unlocked to door to get out, as soon as I popped the door opened, it locked itself again. I tried to pull on up on the door lock, but it felt really stiff like it was fighing me. I then let go, it relocked itself and then I tried again and it free'd back up like normal.
Old Jan 7, 2005 | 07:00 AM
-shock211-'s Avatar
Originally Posted by MrGone
today
should we be nervous?
Mar 12, 2020 12:06 AM
Hailstatejig
Sep 2, 2015 06:52 AM
