horn problems
Old Jan 10, 2005 | 12:33 PM
4thgradedropout's Avatar
horn problems
ok my horn has not worked but once since i got the car i checked the fuse and it is good anyone got anyideas?
Old Jan 10, 2005 | 01:10 PM
internetautomar's Avatar
mod or sell?
use a circuit tester to make sure the horn is recieving both power and ground when the button is pushed
Old Jan 10, 2005 | 01:25 PM
blacks92seAuto
look under the hood where the horn is located....i think its right behind the grille. check the wires make sure a ground and power is connected...then test the power wire to see if its getting power at the point of where it connects to horn. maybe the wires are just really corroded from rain, wind, dirt......
Old Jan 10, 2005 | 03:14 PM
rrrfoma's Avatar
My horn stopped working 6 month ago too. So I bought new horns and re-placed old onces. Of course, rusted connectors were the problem.
Check ground and power as suggested above. Clean from rust and put some grease inside - so you wouldn't ever touch 'em again
Old Jan 10, 2005 | 03:21 PM
MaximamixaM's Avatar
Get a "General Lee" style horn.
Old Jan 10, 2005 | 03:30 PM
whitemax28's Avatar
check the horn relay. Or do what I did and get an air horn.
Old Jan 10, 2005 | 05:23 PM
rrrfoma's Avatar
train sounds? - must be very usefull in NYC
LOL
Old Jan 31, 2005 | 07:11 PM
PINKSTA's Avatar
i had the same problem change the relay!!!
Old Feb 7, 2005 | 11:34 AM
phillyphil90's Avatar
Yeah it could be the relay. Mine went bad. I got it replaced and my horn was workin fine, until it started going off whenever it I went to sleep. I woke one night and my horn was blarring. I went out in the cold pulled off steering wheel cover and ripped the electrical wire for the horn out. Now I don't have a workin horn. Any advice as to why my horn's blarrin?
Old Feb 7, 2005 | 12:57 PM
alpicone's Avatar
When my horn wasnt working it was the switch on the steering wheel. It was pushed in to far and when and when I put in a new fuse it popped right away. I pullde out the horn put fixed the switch and put in a new fuse. Good as new. It did take a little trouble shooting first to figure out the problem, so get a test light and get to work. The wiring for the horn is pretty simple so you should be able to find the prob easily.
Old Feb 7, 2005 | 01:11 PM
«§»Craig B«§»'s Avatar
BE VERY CAREFUL! If you have an airbag (I know you dont, but the original poster could have had the option since it's a 92), be very careful when using a test light or any other tester around the steering wheel. You can set off the airbag if you get the wrong wire. Basically, dont mess with wires that are in a yellow harness (rather than white; not the wire color - the connector color will be yellow).
Old Feb 7, 2005 | 11:43 PM
Wiking's Avatar
Death in a bag?
Originally Posted by rrrfoma
...Check ground and power as suggested above. Clean from rust and put some grease inside - so you wouldn't ever touch 'em again
--->use contact grease, pls. Std grease is an insulator. [I know u meant it, but some readers might insulate their wires]
- If I understand right, airbag wires activate the explosives under u nose when they are grounded. In 'happy' instances needs also the g-sensor activation; but ten years is really too much for these auto matic ammo systems.
...who said it: automatic means spastic? Well, I dont like spastic explosives under my nose. If the bag explodes while your stooped near the wheel, man youre dead instantly!!! If that does not kill ya, if the bag rips, one inhalation of the substances will.
Nice devil devices, eh? Luckily they are quite often stolen while cars are serviced...
Old Feb 8, 2005 | 03:40 PM
alpicone's Avatar
Craig, good call. I should use a little damage control next time. I didnt even think about the airbag since none of my maxima's had them. But hopefully most people will be smart enough to use caution while handling s/t as dangerous as an airbag, like disconnecting the battery.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
