Security Light On, Car Won’t Start
Old Jan 15, 2005 | 03:49 PM
SoMarvelus's Avatar
90 maxima was working fine till clutch and window fell, and while I was fixing window I think I left something in the car and since window was down I reached and unlocked door and when I opened the door the alarm went off which I did not know was I had. Because I’m not original owner I didn’t have the remote to turn it off so I disconnected it from the battery to stop the alarm. I replaced the clutch hose and when I wanted to start it would not even try and turn over nothing happened. Is there a way I can reset the computer?? I heard that maximas have an antitheft mechanism, which cuts off the fuel or something…PLEASE HELP I miss driving my max
Old Jan 15, 2005 | 03:51 PM
Loe max's Avatar
stick the key inside the key hole and turn it to unlock it from the outside. This will turn off the OEM anti-theft.
Old Jan 15, 2005 | 04:03 PM
rrrfoma's Avatar
Unlock RH door (not driver's side) lock with a key from outside - this should turn off factory alarm
Old Jan 15, 2005 | 04:08 PM
SoMarvelus's Avatar
Turn it which way, more details
Old Jan 15, 2005 | 04:11 PM
SoMarvelus's Avatar
If its not alarm related, what else could it be
Old Jan 15, 2005 | 04:16 PM
rrrfoma's Avatar
LOL!!! There is only ONE WAY to unlock door from outside with a key.
If you need to reset computer - just disconnect battery for 1 hour.
Old Jan 15, 2005 | 04:18 PM
rrrfoma's Avatar
If you have auto tranny - move shifter a little (sometimes it doesn't see position P)
Old Jan 15, 2005 | 04:23 PM
SoMarvelus's Avatar
Its a 5spd
Old Jan 15, 2005 | 04:46 PM
internetautomar's Avatar
mod or sell?
is the security light still on after you unlocked all the doors from the passenger side with the key?
Old Jan 16, 2005 | 07:33 AM
SoMarvelus's Avatar
i'll try that, the car is at my in-laws shop i'm prolly gonna do that tuesday what is that supposed to do
Old Jan 16, 2005 | 07:56 AM
tripleGmax's Avatar
it will turn off the factory alarm, just like everyone has said. if you lock from outside and open from inside, think about it, thats a simple break in. so to fix it just lock/unlock the door. problem solved.
ps what is that car in your profile.
Old Jan 16, 2005 | 12:21 PM
Wiking's Avatar
Older versions ECU will not allow starting if camshaft sensor is shorted/disconnected, dash light will be on.
Take off distributor, rotate it and measure fluctuating 5 volts on cam sensor pins 2&3.
Old Jan 18, 2005 | 09:11 AM
aziphrale's Avatar
thats a photochopped max. Look at the color of the paint between the door and the wheel You can see the merging that he tried to do. Horrible. But a good car if they were to exist. Lmao
Old Jan 19, 2005 | 12:58 PM
90MAXGMG's Avatar
I don't know if this damages the car in any way but if the car won't start because of the alarm...
1) pull the horn fuse (to stop the horn from blowing)
2)Pull the electronic ignition fuse
3)start the car
4)replace electronic ignition fuse, not the horn fuse or horn will once again, start blowing
The security light will eventually go off. This has worked for me every time with my car...as long as you can go without using your cruise control! I've found that the cruise is wired through the horn fuse some kind of way.
Old Jan 19, 2005 | 03:40 PM
lalo's Avatar
why not get the S# from behind the glovebox and re-program the alarm (keypad)?? that way you would know for sure if it was the alarm, but usualy you could just turn the key on the driverside to get the alarm from going off.
I just reprogramed mine yesterday, so thats proly why im mentioning it. took like 10 min
Old Jan 21, 2005 | 10:46 AM
SoMarvelus's Avatar
what would i need to reprogram
Old Jan 22, 2005 | 05:42 PM
'90Maxima's Avatar
Immoblizer?
my '90 max has an immoblizer, you may have a switch under your glove box which in my case activates "valet mode" if the valet mode is off and i disconnect and re- connect the battery the car wont start, simply turn valet mode on to disable the alarm (switch on/off with ignition on)
Old Jan 23, 2005 | 08:23 AM
lalo's Avatar
(DMAD8724) How-to activate/reset your digital touch entry system (GXEs only)
http://www.cardomain.com/memberpage/454290/7
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
