Whirring Noise on 5 speed trans
Old Jan 16, 2005 | 05:03 AM
FasMaxVE's Avatar
My trans makes a whirring sound mostly in 4th & 5th gear....I checked the fluid level and made sure its topped off. It sorta sounds like gears meshing without lubricant......
Old Jan 16, 2005 | 05:36 AM
internetautomar's Avatar
mod or sell?
IIRC that would be the input shaft bearing going.
Old Jan 16, 2005 | 06:51 AM
Wiking's Avatar
Few yrs ago I bought a small Adam Opel (red!). Drove it home (300miles), started whining on the trip. Decided to change tranny oil: could not. There was none... Well, added some and been playing four yrs since. Whining: add insulation:) - to car or ears.
If its the gears, they might lose, wear some of their surface, and become noisy, like possibly in Adam's case. Noise is the 'only' problem. Not speaking of input shaft... Go to dealer service and ask for quotation; they know the problem by noise, and price.
Old Jan 16, 2005 | 01:58 PM
FasMaxVE's Avatar
How much will it cost me to replace or rebuild the input shaft.......(5 spd. VE with LSD.) its the drivers side thats bad.
thanks Matt
Old Jan 16, 2005 | 04:42 PM
subs1000w's Avatar
1st theres only on input shaft and 2 if your going to be replacin the bearings on the input shaft you mine as well replace all the bearings in the trans
i would estimate a rebiuld around 1k from a good trans shop
if you pull the trans and take it there i was quoted 400$ plus parts so thats the cheaper way to do it
Old Jan 16, 2005 | 04:48 PM
Matt93SE's Avatar
STFU n00b!
whining in 4th and 5th gears is a mainshaft or differential problem. whining in the lower gears is input shaft bearings.
Either way, a rebuild will cost you about $1000.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
