Drive axel seating
there's a little ring on the end that is supposed to keep the axle in place once its in. have you tried putting some oil on the splines and little keeper ring? if not, i'd try that and try putting it back once you do.
ok, i'm guessing the little ring on the end may some how be too small or too big. i've tapped the axel back in but when i turn the hub through maybe 5 rotations it works itself loose. i've done this ten times now. the new axel came with a new ring. the new ring also seems to be shorter as in there is a 1/4' gap between the two ends of the ring, if you can picture it. it might be a bigger gap than the orgional (which is sadly back at the shop and unavailable) but i'm fairly sure the ring isn't clicking entirely into place.
Nissan, Maxima SE '94 5spd Parting out.
CV joint. I really have no idea why its this hard. I've adjusted the o ring but I don't see how it really changes anything. I'm guessing that the inner end of the axel isn't long enough and the o ring isn't snapping out. I've seated the axel as far in as it will go, many times. And it always slips back out after a few turns of the axel.
get a new clip, it is 87 cents at the dealership. I used the old clip and my drive axle fell out going 90 on the nj turnpike and ground up the splines. Im currently looking for a new transmission over an 87 cent clip.
Maxima30
Sep 7, 2015 06:13 PM
