Fuel Injectors Recall or service bulletin for '89
Old Jan 26, 2005 | 09:52 PM
slow's Avatar
Is there one of these. A mechanic said there is, but I can't find documentation. A few dealers said it was only up to 88.
The car has a gas odor; I think I get a headache and bitter taste.
Yes I noticed the sticky.
The smell does not go away after the car warms up.
I am in SoCal and it does not happen just when it's cold.
It's a strong smell that gets into the seats, etc. It's an old car that's slowly dying.
The mechanic already looked at the car. Would he not normally check the rubber fuel lines? I guess I could go back and ask about it specifically.
The heater and A/C do not work. There is some heat coming from the engine thru the vents (without the fan) however. I am not sure whether the smell comes from the vents.
The dash and controls are digital.
Old Jan 26, 2005 | 09:56 PM
subs1000w's Avatar
if the gas oder is coming from the front its proboly just cracker rubber fuel lines very common just replace all pressurized fuel lines under the hood and it should go away
Old Jan 26, 2005 | 10:06 PM
xnyc's Avatar
check stickies
Old Jan 26, 2005 | 10:46 PM
slow's Avatar
The mechanic already looked at the car. Would he not normally check the rubber fuel lines. I guess I could go back and ask about it specifically.
The heater and A/C do not work. There is some heat coming from the engine thru the vents however. I am not sure whether the smell comes from the vents.
Old Jan 26, 2005 | 10:57 PM
slow's Avatar
Old Jan 27, 2005 | 07:39 AM
xnyc's Avatar
stickies has a link to the nhtsa also. no recalls on the injectors. sry but im not sure wats wrong with your car. theres another link in stickies to autozone trouble shoot. might help.
Old Jan 27, 2005 | 10:29 AM
Maxpwer's Avatar
No turbo, no care!
Your mechanic is close... there was a recall on injectors for the vg30 in the 300zx, but not on the maxima.
Old Jan 27, 2005 | 09:27 PM
slow's Avatar
I told the mechanic about the rubber fuel lines, etc. Assuming he understood what I meant, he said something about fuel injectors not being separate from the fuel lines or the rubber hoses and that they have to be replaced together. Is this correct or is he talking about something else.
Old Jan 27, 2005 | 09:39 PM
slow's Avatar
I also just noticed leaks in a few spots under the car. I think he said there were no leaks. Interesting. It's a VG30 (E).
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
RealityCheck
Oct 2, 2015 06:34 PM
