Upgrade Fuel Pump
Old 01-31-2005 | 02:16 PM
Akuma2001's Avatar
Upgrade Fuel Pump
I got a kit that has all the tubing but it also has a wiring harness so I'm not sure what to do with that. I just thought that you switch the pump and filter and everything else stays the same. Does anybody have a write-up on how to upgrade to a Walbro 255 LPH fuel pump in a 3rd gen SE?
Old 01-31-2005 | 02:25 PM
Mizeree_X's Avatar
Getting back to his roots
May I ask why you are upgrading to a 255? Are you running forced induction, or a large nitrous kit?
Old 01-31-2005 | 02:28 PM
Akuma2001's Avatar
My pump was getting very loud. I also suspect that the fuel pump was from a junk yard because the car seemed to have been in a rear end collision. So I figuered if I'm going to buy a fuel pump I might aswell buy a higher performing one.
Old 01-31-2005 | 02:32 PM
subs1000w's Avatar
mine came with 2 wire that had to be spliced into the old harness
Old 01-31-2005 | 02:38 PM
Akuma2001's Avatar
Does the pump require more voltage than the stock one?
Old 01-31-2005 | 03:02 PM
Akuma2001's Avatar
Does anybody have a write-up on this topic?
Old 01-31-2005 | 04:04 PM
internetautomar's Avatar
mod or sell?
more pressure on a stock car will not gain you any advantage.
Old 01-31-2005 | 04:24 PM
Akuma2001's Avatar
Should I have just bought a stock fuel pump for the same price?
Old 01-31-2005 | 05:07 PM
subs1000w's Avatar
no the pump does not require more voltage althought ive heard some run a new relay and thicker wire for a better connection
this pump will work fine althought your fuel pressure will go up it wont affect drivability
mine went up to 52psi and its suposed to be at 43psi. nothing my adjustable FPR cant fix
Old 01-31-2005 | 05:10 PM
Akuma2001's Avatar
When I do install it, should I also install an FPR?
Old 01-31-2005 | 11:19 PM
subs1000w's Avatar
you dont have to i only did to lower pressure to get the right A/F ratio but its a performance thing
Old 02-01-2005 | 05:57 AM
Brad92SE's Avatar
Just follow the instructions that came with the pump. As for the wiring, I removed the stock wires from the terminal and soldered on the new wires running from the walbro harness.
Old 02-01-2005 | 06:57 AM
Mizeree_X's Avatar
If you don't lower the pressure won't you be running pig rich?
Old 02-01-2005 | 01:08 PM
Akuma2001's Avatar
Is there a way to set the fuel ratio without getting an FPR?
Miket2006
03-01-2021 03:55 AM
06-06-2017 02:01 PM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
Quick Reply: Upgrade Fuel Pump
