What have you fixed with org help?
Old Feb 3, 2005 | 09:24 AM
bhunter's Avatar
What have you fixed (not mods) with help from the org? Either just reading stickies or other posts, asking questions. Here's mine so far.
1. Dying problem (relay)
2. Bucking problem (coil pack)
3. Clock repair
4. Door lock timer repair
5. Sagging door repair
6. Bose amp repair
7. Power steering HP hose
8. Front brakes
9. Rear brakes
Thanks org!
Old Feb 3, 2005 | 09:31 AM
Wiking's Avatar
3. Clock repair
6. Bose amp repair
8. Front brakes
9. Rear brakes
Thanks org!
10. Cold computer Maximized lonely Feelings
11. bad Knock Sensor gas consumption
-3: Clock is still bad... but anyways thanks Craig for info.
Old Feb 3, 2005 | 09:34 AM
El Barto's Avatar
I fixed my starting problem and learned about the 3rd gen's window regulator problem (I just another regulator replaced today, thats 2 in less than a year).
I haven't had any other problems with the car yet, but when I do I know where to look.
Old Feb 3, 2005 | 10:13 AM
aw89maxSE's Avatar
everything except the tranny
Old Feb 3, 2005 | 11:56 AM
subs1000w's Avatar
WAYYYYYYYY to much to list
Old Feb 3, 2005 | 12:14 PM
Scope's Avatar
Im izz sexay
Every VG problem. If I can only fix my auto into a 5 speed manual that'll be sweet.
Old Feb 3, 2005 | 12:34 PM
Michael's Avatar
Back in a 3rd Gen.
nothing...I cause problems from reading the org j/k but I honestly dont know what I have fixed with the orgs help (not saying it hasnt helped I just dont know with what).
Old Feb 3, 2005 | 12:40 PM
MrGone's Avatar
clock? (well not mine but other peoples)
probably more but I dont really remember.
future:
Auto Climate Control, since Craig and Michael already figured it out makes everything easier for me
The only thing I haven't removed from my car has been the body panels,engine and rear crossmember, oil pan to heads, ABS system and fuel hardlines and the wire harness. Everything else has been touched
Old Feb 3, 2005 | 12:42 PM
Cliff Clavin's Avatar
Way out West
Almost everything I have done to the car.
I think if it weren't for MrGone, I would have saved myself several hundred dollars on mods.
Old Feb 3, 2005 | 12:44 PM
HTPerformance's Avatar
I have really only gotten some modding ideas, fixing stuff is fairly easy. Get an FSM.
Tip for everyone if they want to lean about the entire car is to take one completly apart, and then reassemble, then you will literally know the car inside and out.
Or just ask MrGone, cuz he thinks he is GOD.
Brian
Old Feb 3, 2005 | 12:45 PM
MrGone's Avatar
I had nothing to do with the y-pipe
Old Feb 3, 2005 | 01:16 PM
Scope's Avatar
Im izz sexay
Uh he didn't say anything about a y-pipe.
Old Feb 3, 2005 | 01:35 PM
Michael's Avatar
Back in a 3rd Gen.
he said mods right?...the Y pipe is a mod...I want a Y pipe.
Shawn I had nothing to do with "figuring out" the ACC swap...matter of fact I slowed it down by reading the wrong wire on the ECU Craig did all the figuring and then explained it to me again and again and again lol. When we planned it I was originally going to do research on it but before I even started Craig said he had it figured out (he didnt have a job at the time and was bored a lot)...why argue lol.
Old Feb 3, 2005 | 01:43 PM
MrGone's Avatar
Chris was saying I'm to blame for all his mods. I replied not the y-pipe because he bought the y-pipe before I knew Julio was selling it
Michael, lol, either way it's on my list . The hard part is finding the parts (atleast for me it is).
Pauls 98 SE's Avatar
Fuel Injectors and knock sensor. I never would have been able to do this on my own. Thank you to all who contributed to the write ups I used!!
Old Feb 3, 2005 | 02:40 PM
5 ltr. beater's Avatar
I learned how to fix my dashboard lights so that I could see my gauges at night time and also fix my hazards that weren't working anymore.
No one has helped me fix my defroster yet. I'm sure someone will find a fix for that one too.
Old Feb 3, 2005 | 02:54 PM
MrGone's Avatar
First determine if it is the switch or the rear defroster itself. If it is the rear defroster itself then buy some of the conductive paint and patch the broken part on the rear window. Napa carries it .
Old Feb 3, 2005 | 02:59 PM
well the switch works fine. It lights up when pressed. I'll look for cracks in the line. I figured that if there was a section missing in the window, it would still work, just not the section of the window not receiving any power. I'll go check right now for cracks in the line. thanx.
Old Feb 3, 2005 | 03:15 PM
Scope's Avatar
Im izz sexay
MrGone was just like the Y pipe was not his fault. Usually a guilty conscience will make someone tell on themselves before ever being told what. That is why I stated that unknowingly of what transactions occured between the two of them.
Old Feb 3, 2005 | 03:27 PM
Jeff92se's Avatar
I'm needing a caw
Nothing. Nothing has ever gone wrong with my car at anytime, anywhere,anyplace. And my car is completely stock. .org is a big waste of time.
Shawn I call on your claim. You have never removed any of your glass.
Old Feb 3, 2005 | 03:33 PM
MrGone's Avatar
true story
Old Feb 3, 2005 | 04:45 PM
tripleGmax's Avatar
my car, The Org helped me fix my car.
thank you org, thank you.
Old Feb 3, 2005 | 05:04 PM
internetautomar's Avatar
mod or sell?
I think the window regs, and wiring my remote start.
That was actually from craigb's page though.
Old Feb 3, 2005 | 05:42 PM
GRNMAXDMON's Avatar
i've practically done more moddin' than fixin' if i recall. the biggest thing i've done is converting the car to a 5-speed and thats about it.
MrGone: i have access to gettin' all the parts u need to do the ACC conversion. as of right now i have 3 ACC units laying around as spares. let me know if ur interested.
Michael im still in the hunt for the HUD control unit. so far i got u the necessary harnesses and HUD projector so i'll keep u informed.
Old Feb 3, 2005 | 05:58 PM
Loe max's Avatar
my locked up rear trunk that I couldn't unlock with the key and my slave cylinder issue that could have ended in a rear-ending that day.
Old Feb 3, 2005 | 06:20 PM
Tony's Avatar
Bad distributor cap (wouldn't start in the rain).
Tony
Old Feb 3, 2005 | 06:52 PM
Greeny's Avatar
¯\(°_o)/¯
Me too!
Old Feb 3, 2005 | 09:26 PM
Tom's Avatar
Tom
-Fuel Injectors
-Thermostat
Old Feb 3, 2005 | 09:41 PM
alpicone's Avatar
On my VE - JDM motor swap. I would not have attempted it without the right-up. I have done carburated RWD motors before but that was my first FWD FI computerized motor swap. Now that I think back to it, it wasnt that much harder.
On my VG, Fuel Injector. Didnt have any other problems.
Old Feb 4, 2005 | 06:19 AM
mod or sell?
A motor replacement is a motor replacement, doesn't matter whether it's a diesel, a gas motor, 3 cylinder or W8, Quad turbo or no turbo.
The same principles always apply.
Drain all fluids from motor
Unbolt the mounts, unbolt the drive coupling, unplug whatever connectors are there. Yank motor.
Do the reverse for reinstallation.
Old Feb 4, 2005 | 02:02 PM
lalo's Avatar
Im still pretty new but so far,
* Saab/Taurus Cup holder <<best mod ever
* Replacing shocks/struts.
* 4 Disk brakes/calipers
* Correct Sparkplug type (NKG copper)
* Emergency lights fixed
* Introduced to Stillen body kit (hoping to install later in the future,maybe)
Maxima_Joe
Nov 25, 2015 08:19 AM
conansriver
Sep 3, 2015 06:38 AM
Quickgtp
Aug 27, 2015 02:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
