Door lock blues..
Old Feb 4, 2005 | 11:18 AM
Brooklyn Legend's Avatar
Door lock blues..
Driver Side door lock not locking or unlocking automatically. I must lock it manually by hand and open by hand.
What sucks more is I have to unlock the door with the key through the passenger side because the driver side door lock key cylinder is some how jammed. I can lock the rest of the doors with the key pad because its a GXE., but again the driver side wont lock with key pad.
Any sugestions I opened driver door pannel and sprayed WD-40 on the lock mechanism and key cylinder.
no dice the stick goes up and down but not automatically.
Help...
Old Feb 4, 2005 | 01:39 PM
Wiking's Avatar
Maybe lock **** sw is out of alignment.
Theres also thermal circ breaker (bad?) for the lock motor (bad?) ...called in FSM 'posistor'.
Old Feb 4, 2005 | 03:36 PM
Maximum Depth's Avatar
I might be the door lock actuator. I had a similar problem with one of my door locks, while the others all responded to the lock switch. My door lock problem was sporatic, most of the time it didn't work, but sometimes it did. I installed a door lock actuator off of eBay for $20, and no more problem.
Old Feb 4, 2005 | 09:14 PM
andy044's Avatar
RWD bolt-on conversion?
yo i had a similar problem
i baught some liquid graphite for like 3.50 sprayed that **** in theer and now it slides like butter.
it was in an erasol can, white with red top? and its like a black-gritty spray that comes out.
Old Feb 5, 2005 | 07:35 AM
were did you spray it in?
Old Feb 5, 2005 | 01:31 PM
Governor's Avatar
Soak the sh_t out of lock(Keyhole) with wd-40 I mean half a can till it turns!! then put graphite inside keyhole..I recently did this to all my locks to get them to work....make sure you put graphite in when done!
Old Feb 5, 2005 | 01:47 PM
goon9's Avatar
Shavedmax has a kit for 175 to shave your handles and add poppers. Great deal and no more problem with locks.
Infact it's VERY hard to steal. Recntly I had to smash out my window to get back in, lol. So for anyone who has no door handles, be sure to have a emergency entry system hooked up.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
