Matt's Next Project of the Week.... (watch out 56K)
Old Feb 7, 2005 | 07:20 AM
  #41
ozzombie13's Avatar
I will eat your children
will that throttle body spacer work with a vg also. if not will you be making one for the vg
Old Feb 7, 2005 | 08:05 AM
  #42
DanNY's Avatar
Ad·min·is·tra·tor
it will NOT work on a VG motor.
Old Feb 7, 2005 | 08:18 AM
  #43
Matt93SE's Avatar
STFU n00b!
Bejay, I'll take a look at making some 4 gen ones, but I need a guinea pig to work on first. best bet would be a spare IM and throttle body.
The ID on the spacers is 61.X mm, and I think the OE throttle body is the same. I sent an OE throttle body to my machinist and just had him make me 10 spacers for it it, and he didn't send the TB back with them. I've already bored out my TB to 64mm and the IM was even larger, so I can't really say where they are now. I think my IM is ~68mm and the TB outlet is 64mm. I flared out the spacer on my car to match the IM and TB.
Cheezer, longer spacer doesn't mean more air per se. yes you have more volume behind the throttle body now, but only by about 25cc. . The 1/2" material is $$ enough as is. It's also the thickest you can make it without having to make a custom bracket for the throttle and cruise control cables. I ran the adjuster nuts down as far as I could on them, and they just barely fit on there without pulling the butterfly open any.
currently I have no plans to make one for the VG, but if enough people want them, I can see about it.
The VE one will be $40 including the new, longer bolts to fit. I have 8 of the spacers in stock, but I need to order the bolts. should be here in a week or so.
Old Feb 7, 2005 | 08:32 AM
  #44
blackandwhite's Avatar
To them I'm like an idol
Okay...for fear of sounding like a total dumba$$ here, what exactly is gained by a throttle body spacer?
Old Feb 7, 2005 | 08:51 AM
  #45
Matt93SE's Avatar
STFU n00b!
supposedly it helps to increase airflow velocity or swirl speed or something like that. they're hugely popular on the domestics (yes, even ones with fuel injection), so I thought I'd try it and see. seems to be worth a couple HP, and it's also an easy way to open up your TB and IM bores and use the spacer to match both diameters.
Old Feb 7, 2005 | 12:38 PM
  #46
MrGone's Avatar
That goober!
I can attest to the gains EFI SBFs see with them.
Old Feb 8, 2005 | 01:57 AM
  #47
Cheocwa's Avatar
Dang, too bad I can not get it. I want to stay in class btw how did you do in the auto-x? I got one on the 19th and 20th
-Larry
Old Feb 8, 2005 | 06:13 AM
  #48
Matt93SE's Avatar
STFU n00b!
I sucked it up bad- as I usually do. of course I'm stuck in SM and the field is pretty tough. about 2.5 sec behind the leaders. But then again, I was on my all-season street tires this month and not my slicks..
Old Feb 8, 2005 | 06:20 AM
  #49
avmaldo's Avatar
I would by a vg version if you made them matt!
Old Feb 8, 2005 | 07:53 AM
  #50
Matt93SE's Avatar
STFU n00b!
Someone send me a VG throttle body and I'll see about getting some made..
Old Feb 8, 2005 | 08:05 AM
  #51
DanNY's Avatar
Ad·min·is·tra·tor
want me to send you one?
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
tv314
Apr 5, 2016 04:54 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Domf3
Sep 22, 2015 03:05 PM
