Smoke from front of car
Old Apr 29, 2001 | 09:11 AM
PrinzII's Avatar
OG and counting...
Last night, I noticed a little smoke (similar to steam)from the front of my car when it was stopped. The coolant level is fine and I changed the oil Friday.
Old Apr 29, 2001 | 09:46 AM
kaleb's Avatar
Had you driven the car since you changed oil?
Often oil will spill on the exhaust pipe, engine block, valve cover, or rear exhaust manifold when the oil filter is removed or when you're filling the crankcase with oil.
It's simply vaporizing itself. Check the area around your oil filter and oil pan drain plug with a flash light while the engine is running and up to operating temperature to make sure there are no leaks. Be careful, the areas around where you're checking will be hot.
-Kaleb
Old Apr 30, 2001 | 01:45 PM
PrinzII's Avatar
OG and counting...
I'll try that out and see what I come up with.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
