Automatic window roll downer thingy
Old Feb 6, 2005 | 03:37 PM
mtnbikeair's Avatar
I read on some site that the maximas have the button to roll the window down automatically. I interpreted that as you touch it once and it goes all the way down. I have that ****, button, or whatever you want to call it but when i touch it the window goes down about 1/3 of the way on its own and then stops. Is that how its supposed to work, or is mine broken and if so how do i fix that? Thanks in advance
Old Feb 6, 2005 | 03:52 PM
internetautomar's Avatar
mod or sell?
I think craig has some info on hoe to fix it on his site
Old Feb 6, 2005 | 03:57 PM
mtnbikeair's Avatar
Thats where i found out that the window was an automatic roll down thing, but his site shows you how to make it go up on its own too, not how to fix the rolling down.
Also internetautomar i sent you a PM about exhaust. Thanks
Old Feb 6, 2005 | 10:56 PM
dewmax007's Avatar
I have similar auto roll-down, roll-up issues and they are indeed attributed to a worn window control panel. using craig's site I too changed my auto-down so it will auto up as well. I have found that in humid weather and cold weather this modification hasn't worked as well as I had hoped. MOST of the cause would be age and condition of the panel itself.
does that really answer your ?, probablly not...but another look at craig's site may help. Good Luck
Old Feb 7, 2005 | 05:21 AM
Michael's Avatar
Back in a 3rd Gen.
the problem is in your switches. I have had this problem...swap the switches and it goes away.
Old Feb 7, 2005 | 07:39 AM
blackandwhite's Avatar
To them I'm like an idol
Well...
That's not how it's supposed to work. I had the EXACT same problem. After my window regulator failed on my VG, I had it fixed at a local shop. After that, the "roll all the way down" function started acting exactly like yours, rolling only about 1/3 at a time.
Old Feb 7, 2005 | 01:54 PM
Eric95se's Avatar
so what is the verdict on this 1/3 roll down syndrome? Mine does it too, but I assumed it was the regulator, because the action was a bit slow. Now I am led to believe it is the entire switchboard? I looked at priced, it is over 100 bucks. I won't pay that just so I don't have to hold down a button.....
Old Feb 7, 2005 | 02:13 PM
ghostmax's Avatar
It's worn switches...period. I went to a junkyard and found a practically brand new switch (still had all the letters), and the window rolled up (after mod) and down all the way. I paid $20 for the master switch.
Old Feb 7, 2005 | 05:29 PM
Eric95se's Avatar
link to craig's site? anyone?
Old Feb 8, 2005 | 11:31 AM
DennisMik's Avatar
http://www.4dsc.com/articles/
Old Feb 8, 2005 | 11:36 AM
Michael's Avatar
Back in a 3rd Gen.
Although a very good site it's not Craig's.
The answer is in the stickies but I will go ahead and post it anyway.
click here and then click on how to
Old Feb 8, 2005 | 12:40 PM
DennisMik's Avatar
OOps - sorry.
Old Feb 8, 2005 | 01:30 PM
3rdmaxse0's Avatar
its most likely the capacitor in the circuit
Fbana41
Aug 29, 2016 12:18 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
