A/C Question
Old Apr 29, 2001 | 09:03 PM
PrinzII's Avatar
OG and counting...
I am getting ready to recharge the air conditioning on my '94 GXE but I am unsure whether or not my car is running R-134 or R-12 refrigerant. The dealer I take my car to said there are a fair number of '94 Maximas running around with R-12 (That baffled me because I thought Federal law mandated that the manufacturers switch to R134 in 1992 ). Is there an easy way to tell which type of refrigerant I am running?
Old Apr 29, 2001 | 09:23 PM
fornimage's Avatar
A/C...
A simple way to check is to look at the fittings where the refrigerant is charged into the system. Simply speaking if the fittings on both the low side and the high side has threads on them then there is a good chance that is uses R-12. If it looks like a quick disconnect type fitting then it uses R-134a. Hope that helps.
Old Apr 29, 2001 | 09:26 PM
John van de Pol's Avatar
AC refrigerant
There should be ample id stickers under the hood, and little blue stickers on a number of he components (like the compressor) as well
John
Old Apr 30, 2001 | 08:09 AM
PrinzII's Avatar
OG and counting...
Re: AC refrigerant
John
Do those blue stickers indicate whether or not the car uses R-134?
Old Apr 30, 2001 | 11:32 AM
fornimage's Avatar
Blue sticker means R-134A. n/m
n/m.
Old Apr 30, 2001 | 01:27 PM
dch95's Avatar
Quick question....
Are you recharging your system because of previous maintenance that was done which called for removal of A/C parts? Or are you recharging because it,s not as cold as it used to be? If the latter is the case, you will be wasting money because you have a leak somewhere which needs to be fixed. Refrigerant is constantly recycled in the system and is NEVER consumed/wasted in the process. Just some FYI.
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
