What's causing this
Old Feb 10, 2005 | 10:28 AM
MAXI's Avatar
What's causing this
This morning while i was warming the car, i put a little gas just to make the RPM go up to 1500. I notice some low backfires while idling. Whats the cause of this??
Old Feb 10, 2005 | 10:32 AM
Jeff92se's Avatar
I'm needing a caw
It's either electrical, mechanical or fuel related.
Old Feb 10, 2005 | 10:34 AM
Alex_V
The hand of god perhaps??
~Alex
Old Feb 10, 2005 | 10:53 AM
Wiking's Avatar
~Alex
will-o'-the-wisp = low back fires - seen in the horizon?
...definitely ungodly hands...
Old Feb 10, 2005 | 11:37 AM
internetautomar's Avatar
mod or sell?
VE?
VG?
probably an injector either way, but more info and we can lead you down the right path
Old Feb 10, 2005 | 12:14 PM
MAXI's Avatar
VE?
VG?
Ops, i forgot that....anyways, its a VG30.
Old Feb 11, 2005 | 01:41 AM
Wiking's Avatar
Give more info = Get more info
Car history is the key: how many miles, what maintenace has been done, any other problems.
Old Feb 11, 2005 | 09:11 AM
mod or sell?
disconnect the wires one at a time until you find 1 that DOESN'T change the way the car is running
Old Feb 11, 2005 | 07:33 PM
max_pusher's Avatar
When is the last time you do a tune-up (plugs, wire, cap, rotor, fuel filter, etc.)?
Old Feb 11, 2005 | 08:00 PM
Scope's Avatar
Im izz sexay
Maybe a two plugs are in the wrong arrangement. When I changed my plugs two weeks ago I ended up swapping two of the plugs and when I pressed the gas and let off of it I would hear a backfire. I figured out which two were wrong swapped them and haven't heard the backfire since.
Old Feb 11, 2005 | 11:46 PM
DJ Kontakt's Avatar
change your oil, i bet they go away after the car warms up.
Maybe it doesnt like the weather.
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
