How do I test a MAF?
Old Feb 11, 2005 | 08:46 PM
disgruntled's Avatar
I bought one off the junkyard for like 20 bucks, the car had 250+ k miles on it, so what is the easiest way to test the MAF without trying to plug it in as I don't want to disturb my current MAF.
Old Feb 11, 2005 | 08:51 PM
Mizeree_X's Avatar
Getting back to his roots
I would just switch MAFs. If the car runs fine, the junkyard MAF is good. If not, switch MAFs back. I doubt you can cause any damage to the engine by switching MAFs for a short period of time. A telltale sign of a bad MAF is that the engine won't rev over 2000 RPM.
Old Feb 11, 2005 | 08:58 PM
Thanks for the quick reply, I know about the maxima's "limp home mode", but I was looking for a method like measuring with a multimeter or something, I just bough this MAF because it was cheap, and it was the only MAF left intact in the yard. and the reason I don't want to switch is that I have a habit of overdoing things, and might damage the current MAF that I have.
Old Feb 11, 2005 | 11:31 PM
Wiking's Avatar
To see if your 'new' MAF is possibly ok, compare resistances with one in your car. Take its connector out and measure... Compare; you will notice if resistors broken.
OR: Put +12V & gnd in the same pins u get in the car. Put a DMM probes into MAF pin b (second from left) & gnd should get 1V reading. Blow air through, should see slightly increase.
http://www.cardomain.com/memberpage/748507/9
Old Feb 12, 2005 | 03:29 AM
KUOCH's Avatar
hey if it works good and you dont need it I will gladly buy it off you i need a replacement and to get a new one is too expensive
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
