Small idle problem
Old Feb 11, 2005 | 09:26 AM
95turbo gxe's Avatar
Small idle problem
When I crank my car it idles up like it should and back down to300 to 400 real quick and then almost cuts off. Then it goes to 800 and does fine from thier. What could cause that.
Old Feb 11, 2005 | 09:37 AM
I still got stock injectors
Old Feb 11, 2005 | 10:26 AM
internetautomar's Avatar
mod or sell?
CTS?
IAC?
Loose nut behind the wheel
Old Feb 11, 2005 | 10:49 AM
Wiking's Avatar
If it was intake leak, it should be continuous. Or such a leak that the vacuum would 'self seal' the leak. Pwr valve Canister or the fuel vapour canister system hoses? Block the hoses to tst.
Fuel pressure problem; regulator valve or its vacuum?
Check out the voltage level, how is it behaving?
Take out A/C and pwr steering to tst.
Old Feb 11, 2005 | 11:12 AM
Harvs94max's Avatar
where is your iac valve hoses hooked up charged or non charged side and then i think the intake manifold hose that you have youshould try just have a filter on it (intake manifold) and have the hose on the intake tube caped
i dont know a whole lot about turbos but just a suggestion i know that is how my friend with a miata had it and a civic that i worked on had it
Old Feb 11, 2005 | 01:49 PM
its on the charge side
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
16_SR
Sep 9, 2015 07:14 PM
