cars smoking?
Old Feb 11, 2005 | 03:47 PM
maximaboi's Avatar
cars smoking?
well this is about the 3rd time that I have noticed my car smoking like this. after I park it for a while at least a few hours and then get back into my car if I take off real fast just as soon as I start it it will smoke. that is the only time that I have noticed it smoking. its not a lot of smoke just enough that I notice it. it looks like its sort of black and white in color.
I dont usually notice it using much oil unless I go on a trip on the highway. a few weeks ago I drove about 600 miles on the highway and my car used up about 1 1/2 quarts of oil. I dont know if that would have anything to do with this problem but I thought it could.
what do you think could be causing this smoke? I put lucas in when I changed my oil last time, thought that would help but it didnt b/c I went on my trip after I put in lucas and I had this happen afterwards.
Old Feb 11, 2005 | 04:01 PM
MrGone's Avatar
Could you find out where the smoke is coming from?
Get under the car and try to find an oil leak.
Old Feb 11, 2005 | 04:02 PM
medic's Avatar
any smells from the smoke?
Old Feb 11, 2005 | 08:14 PM
maximaboi's Avatar
it doesnt smell when it smokes or at least that I can smell. like I said I have to take off pretty fast as soon as I turn my car on for it to even smoke.
I know that it used to leak oil till I put in the lucas. since then I have cleaned my engine so I cant tell where it was leaking from but it doesnt drip onto the driveway anymore and I have put cardbord under it over night and there were no oil spots on it after I used the lucas.
Old Feb 11, 2005 | 10:14 PM
maximagxe90's Avatar
Hi,
the seal around engine could be worn out,
when i drive my dad car before it would smoke if i drive it when i started the
car until i brought my dad car to the dealer,
and they said that the seal was the cause of the leak and smoke coming from the engine,
how many miles is on the car?
Old Feb 11, 2005 | 11:21 PM
Wiking's Avatar
And you detect that smoke from rear view mirrors??
Youre burning too much ? gas while cold; TPS substitutes until the engine is warm and O2 comes into pic. Clean TPS.
That amount of oil consumption is terrible on maxima; typical on GM etc. Valve seals hardened? Need to take cams/springs off to replace.
Old Feb 11, 2005 | 11:44 PM
DJ Kontakt's Avatar
you have bad piston rings. Time for a rebuild
got lots of miles on the car? If you do then I think Im right.
Old Feb 12, 2005 | 01:10 AM
Wiking's Avatar
Originally Posted by DJ Kontakt
you have bad piston rings.....
Worn/broken rings would cause smoking all the time, worse when hot. Or like the stinking BMW's decelerating... uh uh. The oil theory would also produce blue smoke, not whi/blk as maximaboi indicated.
Old Feb 12, 2005 | 06:08 AM
maximaboi's Avatar
yeah its got 214k on it. I thought that the piston rings might be the problem when I take trips and it uses oil
forgive me if this is a dumb queston but what does TPS stand for?
I have been thinking about getting that rebuild kit that was on a thread a while back
http://www.rpmmachine.com/fr_index.h...mportmenu.html
Old Feb 12, 2005 | 06:38 AM
Wiking's Avatar
1. Isnt it high time to visit my web page?
--->go for it to hit TPS : http://www.cardomain.com/memberpage/748507/1
2. Compression tst should show if rings worn. 214 does not yet kill Nissan engine... I think the valve seals are the cause, can be cahnged quite easily engine on...
Old Feb 12, 2005 | 01:50 PM
Hi,
i have seen some of nissan engine that have more then 214k miles,
some have 300-400k miles on the engine and it still running,
so 214k is noting,
along my dad car has over 271k miles on the engine and it still running and hauling ***,
Old Feb 12, 2005 | 05:18 PM
DJ Kontakt's Avatar
yeah i forgot to say it could be the valve seals too... but wouldnt that cause the blueish smoke too?
Old Feb 12, 2005 | 09:02 PM
usmanasif's Avatar
Originally Posted by maximagxe90
...so 214k is noting,
I beg to differ. 214 is never "nothing" on ANY car. Proper maintenance from day one goes a long way towards extending a car's life. Driving style, conditions, etc all account for how long a car will last. And of course all of them are always different for every car. Maximas are the best cars in their class, no doubt. But they are not immortal!
Old Feb 12, 2005 | 09:03 PM
maximaboi's Avatar
now that I think about it there was also some blueish smoke. this happened yesterday when I was leaving work and I asked the guys at work if they saw it to and they said that it had some blue in it.
Old Feb 12, 2005 | 10:02 PM
DJ Kontakt's Avatar
the need for oil made me think of the rings specifically. Does it get worse if you drive for 30+ minutes and then let it idle?
Old Feb 13, 2005 | 05:48 AM
maximaboi's Avatar
the only time that I really notice it using oil is when I go on long trips. the only time I really drive my car is when Im going to work and going on any trips, and my work is only a mile down the road. so it could be that it would use oil if I drive it for 30 min and then let it sit but I dont really know.
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
