Antenna
Old Feb 13, 2005 | 10:57 AM
lj_canada's Avatar
Antenna
my antenna on my 92 maxima will not go down... when the radio is turned on/off you can hear the motor for the antenna working, but the antenna does not move. it isnt rusted or anything, the antenna just wont go down. another thing is, is that i cant even really find it from the inside.
any help would be great... thanks
Old Feb 13, 2005 | 11:01 AM
-shock211-'s Avatar
pull out the trunk liner on the passenger side of the car. remove the jack and you'll be able to inspect the antenna assembly for any problems. besides the antenna being a tad bent i can't think of much else that would give you this problem. good luck
Old Feb 13, 2005 | 11:04 AM
lj_canada's Avatar
thanks man... i will check that... and its not bent... i wish that is what it was...
thanks
Old Feb 13, 2005 | 02:18 PM
Josh's Avatar
It may be that the plastic teeth that drive the antenna are worn ( i replaced mine for the 3rd time last month), the best you can do is buy a new mast, however that is if the teeth on the actual mast are worn, i'm not sure about if the teeth on the driving gear are what are worn. i would think you have to replace the assembly but that seems like alot of work, and i personaly have not heard of anyone having that problem. you could always just set a stationary antenna if you were ambitous.
Old Feb 14, 2005 | 11:51 AM
ChrisCheezer's Avatar
ebaymotors.com is your friend.
Old Feb 14, 2005 | 12:07 PM
MAXI's Avatar
need to pull out the antenna...write ups are avail, i think 4dsc.com has one. once you have them out, need to open that round thing..thats were the plastic "belt" spools. Inspect if its broken...make your repair decision from there.
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
