ATF Fluid Change
Old Feb 15, 2005 | 07:04 PM
Ivan Yulaev's Avatar
ATF Fluid Change
Ok, so I am planning on doing a tranny fluid replacement. Now, I am wondering, should I just do a simple fluid change? Or should I change the filter as well?
If I am to change the filter, where can I find directions on doing it? Ok, I take off the pan, but where is the filter, and how do I change it?
Old Feb 15, 2005 | 10:39 PM
Wiking's Avatar
Is there a reason for oilchange? Do not touch things that work
I suppose its well documented at www.autozone.com ;login and seek.
Some say here that u should also flush it. dunno.
Old Feb 15, 2005 | 11:10 PM
Unfortunately, I cannot find it in the manual. Also, does anyone have a good source for the parts?
Old Feb 15, 2005 | 11:28 PM
Wiking's Avatar
Thats weird as its 'well' documented in the chiltons manuellos. Go get that one. I thought it was the same...
If you have had slipping problems try this 50$ valve pack:
Service pack for RE4F04A auto tranny: www.txchange.com
Old Feb 16, 2005 | 01:06 AM
ke5adb's Avatar
All you can do is change the fluid. The filter is not serviceable, unless you pull the tranny out and split the case like if you were rebuilding it. So just change the fluid.
Old Feb 16, 2005 | 01:24 AM
Wiking's Avatar
Filter is changeable; basic service tranny on. Pls intruduce uself with the FSM.
Old Feb 16, 2005 | 01:51 AM
ke5adb's Avatar
Well, see, something I wasn't aware of. Thanks wiking, will have to take a look.
Old Feb 16, 2005 | 06:22 AM
internetautomar's Avatar
mod or sell?
clarification.
early VGs have a filter that can only be accessed by disassembling the trans.
VEs have a filter that can be accessed by a pan drop.
not sure about the later VGs
Old Feb 16, 2005 | 06:30 AM
Wiking's Avatar
clarification.
Thanks for clarification:
...at least the 'manuello de chilton crap' gives even pics on that. From outside looks the same. Never actually changed my red clean liquids. Must go with the tranny models?
Have to take the manual and check for my RE4F02A. Comments will follow.
Note1: Chiltons 93-98 Manual connects oil/filter change to RE4F02 (VG) autotranny.
Note2: Chiltons 93-98 Manual connects oil/filter change to RE4F04 (VE) autotranny. With so called pics [spelled: pigs].
Nissan FSM -94 does not tell ! anything related to filter change....
Note3: Get the correction here:
http://forums.maxima.org/showthread.php?t=380210
Old Feb 16, 2005 | 08:17 AM
LMaRiE91MaXiMa's Avatar
Just an uneducated pointer: If you are currently experiencing any kind of transmission problems, changing the tranny fluid actually INCREASES your chance of the problems getting WORSE.
If your just changing it for service reasons (no slipping or other problems involved) then go for it. I changed mine last year and shes still shifting smooth as ice cream...yummy!
Old Feb 16, 2005 | 08:23 AM
alpicone's Avatar
If your fluid is already burned then I would change it because it will mess things up. If your fluid is good and you want to do is as maintnance then change all the fluid if you can. On my vg which had 124k when I sold it,it had a small 1-2 kick from about 100k. When I changed the fluid I did a regular drain and fill. But at 123k I did a complete drain and then pumped out all the tranny fluid by disconnecting the return line from the radiator. After I changed all the fluid the 1-2 kick was gone.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
iamute
Sep 20, 2015 05:22 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxxx10
Sep 13, 2015 03:16 PM
