ABS Question/Problem
Old Feb 16, 2005 | 12:01 PM
greggie195's Avatar
I purchased a fully loaded 1992 GXE in near mint condition recently and it needed a new right axle. I had a friend of a friend (who is a legit mechanic) put one in as a side job. Well he got it in in under an hour and the axle feels great. But now the ABS light is on, and when it's not the ABS activates when I hit about 8mph, regardless of the tires locking or not. I told him about this and he said the sensor probably got some grease on it, and it may come off in time or need to be cleaned. I located the sensor and wiped it with a paper towel. Im sure there is a better way to clean this. Has anyone had this problem or is able to help remedy this annoyance? Thanks alot guys.
Gregg
Old Feb 16, 2005 | 12:06 PM
internetautomar's Avatar
mod or sell?
not too disagree with your friend but, that symptom is usually caused by having the wrong # of teeth on the ABS ring.
Old Feb 16, 2005 | 12:08 PM
-shock211-'s Avatar
well i would use brake cleaner to clean the sensor.
chances are whether the sensor is clean or not, it's on its way out. our abs sensors seem quite fragile. i've gone through a few of them myself. try going to a junkyard and picking up a spare abs sensor.
Old Feb 16, 2005 | 12:11 PM
greggie195's Avatar
Is the ABS ring part of the axle or is it seperate? Can just the ring be replaced, if this is the problem, or does the whole axle need to be replaced?
Old Feb 16, 2005 | 12:15 PM
-shock211-'s Avatar
the abs ring is on the drive shaft. you would have to take out the drive shaft to have a different ring put on.
Old Feb 16, 2005 | 12:18 PM
mod or sell?
whomever sold you the axle is responsible to get you the correct one (assuming that you bought it "new")
Old Feb 16, 2005 | 12:20 PM
Jeff92se's Avatar
I'm needing a caw
Mechanic who replaced the axle failed to remove the sensor. Thus stretching it/damaging the wiring harness.
Do the diagonstic and then tell me it's the right front abs sensor.
Old Feb 16, 2005 | 12:21 PM
greggie195's Avatar
Bear with me for a second, Im not very much up on front end/tranny stuff. Is the axle the same as the drive shaft? I drove a rear wheel drive car for the last 5 years and I know about the drive shaft on that but front wheel Im not sure of. I looked at the new axle today and there are deffinatly teeth there, so I know he put in an ABS axle, if that makes sense.
Old Feb 16, 2005 | 12:22 PM
greggie195's Avatar
It was rebuilt.
Old Feb 16, 2005 | 12:24 PM
greggie195's Avatar
I was reading that you can count the light flashes, but I dont know where the light it located. It says under the boot, I dont know what that means. Is that olde english for hood?
Old Feb 16, 2005 | 12:25 PM
Jeff92se's Avatar
I'm needing a caw
trunk....................
Old Feb 16, 2005 | 12:29 PM
mod or sell?
Originally Posted by greggie195
It was rebuilt.
so then the rebuilder / store that it came from needs to correct it.
Count the number of teeth on the ABS ring, and hopefully someone here will count theirs.
then compare to be sure the correct # of teeth
Old Feb 16, 2005 | 12:31 PM
greggie195's Avatar
internetautomar:
Good idea
greggie195's Avatar
Jeff92se:
Thanks for the translation!
Old Feb 16, 2005 | 01:44 PM
mike92's Avatar
My GXE had the same issue, if it turns out to be the sensor, (check the number of flashes on the ABS computer, located on the trunk near the speaker) try first to rewire it with new cable. It worked for me. The sensor is expensive here in Mexico, about 500 dollars.
Old Feb 16, 2005 | 06:16 PM
greggie195's Avatar
Here's an update if anyone cares:
When I got into my car tonight the ABS light did not go on, but whenever I stop the brake shakes hard, right around 5mph and the car pull slightly left. I restarted it a bunch of times and the light still doesnt stay on so I cant get the diagnosis code. I was reading online that grease/dirt on the sensor can cause this. I think I'll take it in tomorrow to my normal mechanic and ask him to clean it and test the sesnor. Thanks for all the info guys.
Gregg
Old Feb 16, 2005 | 06:52 PM
Loe max's Avatar
mine did this also. I cleaned the sensor and the culprit for my problem was grease also. I think the grease from mine came from a previously slightly torn CV boot that released some grease on the passenger side.
Old Feb 17, 2005 | 10:46 AM
greggie195's Avatar
Update: I took the car in and the mechanic, who I normally use, said it needs a new Master Brake, which I disagreed with. He said the system had no pressure, so I reluctantly let him put one in ($150 installed, which I thought was fair)...Now the ABS light stays on and I can read the error code which is front right sensor which I been saying from day one. He said he'll see how much a sensor will run. I wish I had a lift and all the tools so I could just do this myself. The majority of mechanics dont know anything about what their doing!
Old Feb 17, 2005 | 10:48 AM
Jeff92se's Avatar
I'm needing a caw
Am I good or what? Thing is the mechanic probably broke the sensor wire. He should be paying for it.
Old Feb 17, 2005 | 11:01 AM
Wiking's Avatar
Absolutely so.
Greg, u brought a working vehicle (ABS) and now its been broken by wrong methods. Then u let this ** smoke u 150 for no reason... Pls, do not go there but with a policeman and only demanding a working sensor that someone else will put in...
Old Feb 17, 2005 | 11:08 AM
greggie195's Avatar
Thats the thing that gets me I knew what it was all along, but I dont have the tools to repair it.
Old Feb 17, 2005 | 11:16 AM
Wiking's Avatar
H.Hammer.
U know, I was once there. Almost got killed... Then I decided that I can destroy my car also, ALL FREE. Started buying tools, kept buying. Have 'all' but still missing most...
A tool to repair is better investment than any other u can make. Buy what u need for this.
'Funny' thing -nomen est omen- the shop that decidedly ruined my car, was named H.Hammer.
Old Feb 17, 2005 | 11:46 AM
greggie195's Avatar
Wiking:
Very good advice!
Old Feb 18, 2005 | 12:05 AM
Wiking's Avatar
Wiking:
Very good advice!
...btw: I did take that steering rack bearing to the shop so that he could change it. (I thought I could not.) What is typical: the guy did NOT change it , but added shims on the other end (easier) which later bursted all ballbearings off while driving... Life is interesting as u steering wheel becomes merry go around... Before leaving I asked that guy for the old part: "weeelll, I just cleaned, nowhere to be found" was his answer. --->That guy is a killer.
Lesson learned: any time u car is repaired, stand beside. PAYS. If not, mark the parts if possible: dont leave before u have the old ones with you.
Now anybody try to speak to me that "this and that is dangerous to change byyourself". Hah. Cando even better death traps than those "good ol stealing mechanics"...
Anyways, its always good to ask advice before taking on a repair; these kind forums are one of the places to ask. But there is 'no' such job one cannot do in a car after buying adequate tools. After few blown engines, you become a pro... Some say thats expensive - I say its cheaper: not paid for the mech.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
