Where are the voices?
Old Feb 17, 2005 | 09:29 PM
joeybec007's Avatar
So I got my maxima last year and all seemed great, the bose stereo though antique worked fine and had good overall sound, plus i'm not rich enough to buy a new system. So after gettin an MP3 player for xmas I also got a cassette adapter to play through the deck. Sometime between when I started listening to my MP3 player through the stereo the sound has degraded, in an interesting way. For some reason voices are muted while the instrumental sounds come throug fine. The sound that results from this isn't any fun to listen to, so I was wondering what could be causing this because I tried a regular music cassette and the same problem occurs, so i know the issue is not with the mp3 player or cassette adapter. Any ideas?
Old Feb 17, 2005 | 09:40 PM
disgruntled's Avatar
maybe the tape reading head is dirty? Try inserting one of those casette cleaner tape in there. I think you can get one for less than 5 bucks at a local music store. If not, the read head might be worn due to 14 years of playing, time to invest in an HU then I guess, you can get a cheap *** HU for like 30 bucks, it won't be anything great, but enough to entertain you on your drive.
Edit:
Also to note, when I first got my red max (have since traded in), I was still listening to music through the casette adapter, and the sound was really horrible, for some reason, it did not get amplified right, and I had to turn the volume to maximum just to barely be able to hear the thing. So, it can also be problem caused by incompatible technology.
Old Feb 17, 2005 | 09:42 PM
Cliff Clavin's Avatar
Way out West
maybe you should stop downloading karaoke versions of the songs you like
Old Feb 17, 2005 | 10:04 PM
Hectic's Avatar
edit: nm, i didn't read carfully enough. if it does the same thing with a regular cassete, try cleaning the heads. if that doesn't work...i think it's time to replace the bose.
Old Feb 17, 2005 | 10:40 PM
Vadim-93GXE
Im no expert but, it could be that your speakers are becoming no good. If you have nothing better to do, and your a hands on kinda guy, open your door panel, and gently push on the speaker. If it makes a weird noise, maybe it's cracked. Or maybe your getting bad reception from one of the connecters somewhere in the system. Check it out.
BTW - Try posting stereo related topics in the "Audio and Electronics" forum. Makes things easier.
Old Feb 18, 2005 | 04:11 AM
swowlinc's Avatar
1993 SE
[QUOTE=disgruntled]maybe the tape reading head is dirty? Try inserting one of those casette cleaner tape in there. I think you can get one for less than 5 bucks at a local music store. If not, the read head might be worn due to 14 years of playing, time to invest in an HU then I guess, you can get a cheap *** HU for like 30 bucks, it won't be anything great, but enough to entertain you on your drive.
QUOTE]
Exactly!!
Old Feb 18, 2005 | 04:26 AM
bhunter's Avatar
My first guess too is that the tape head is dirty/defective. Does the radio sound fine? If the radio sounds fine that eliminates the speakers, amps and such.
Old Feb 18, 2005 | 06:49 AM
ozzombie13's Avatar
I will eat your children
ok wait a litle while, save up a little cash like $200-300 and buy a cheap cd player hu and speakers. messin around with tapes is horrible and the bose is just a pain in the *** all around. first thing i did after buyin my max
Old Feb 18, 2005 | 08:16 AM
PunkFriday's Avatar
Power Dorifto Extraordinaire!
Niether one of my maximas have a working bose system. Not fun.
Old Feb 20, 2005 | 12:21 AM
Burgundy91SE's Avatar
Just my .02 here.
When my Bose in the 91 SE totally crapped out and would only play static or not play at all. I went to the local pick-a-part got a Bose unit and CD player out of a Maxima and all four amps. I replaced the defective amp in the passengers side door and installed the radio and it sounded/sounds great and I have not had a problem since. I think I spent 22.50 maybe. Just a suggestion.
coasterswim
Sep 2, 2015 07:43 AM
scutmud
Aug 28, 2015 05:04 AM
Ninety-NineSE
Jan 9, 2002 09:31 PM
SWEETSOUND2001
Sep 15, 2001 10:46 PM
